Jabbasport superpro bushes
Lovely! Thank you (both) for the pics!
Camber is way out on the measurement data you posted. This has to be the reason these bushes have effect, right? What are the possible drawbacks from using them?
"Way out" is a bit exagerative.
It's still within Skoda specifications which is 30 minutes either way of -0.30 degrees (remembering that there's 60 minutes in a degree)
I believe the technician set the anti-lift/caster adjust bushes to reduce pulling to the left which on the test drive proved correct.
Kev
Details from my last alignment for a stock car. only suspension mods is a Jabba RARB.
Toe:
Front total 10' Left 05' Right 05'
Rear total 22'. Left 09' Right 13'
Camber
Front Left -.52' Right -.42'
Rear Left -1.33' Right -1.26'
Castor
Left 4.41' Right 4.36'
