Poll for instrument panel fault.
Have you suffered this fault with the gauges on the Skoda octavia mark one. 64 members have voted
  1. 1. Have you suffered this fault with the gauges on the Skoda octavia mark one.
Please sign in or register to vote in this poll.
This thread and poll is going to be the base of our petition to skoda to get these gauges replaced under warrantee.
What we intend to do, is present skoda with our petition.
If they fail to do anything about it, then we WILL be taking this to BBC's Watchdog.
. If everyone could vote if the've had the problem or not.
. Post what model octavia mk1 it is. (including engine size and trim)
. Also post your dissatisfaction to skoda.
This data will be used to help us get the gauge's repaired free of charge under warrantee, irrespective if the car is out of warrantee, as these cars shouldn't have this problem.
We need video's and testimony's from skoda octavia owners too. (if possible)
Ok here is the petition.
We the undersigned.
Petition to Skoda,
To make an offical recall to the Skoda Octavia mark one.
The fault is with the gauges, It can be intermittant.
They all zero whilst driving, which is dangerous as you cant tell the
Speed of the car, the revv's, the temperature, or the fuel level.
The trip computer carries on working, and the mpg.
However a temporary fix has been discovered by the users of "briskoda.net"
to remove fuse no. 15, which zero's the digital trip gauges, but the dials
now function, however they dont function correctly.
The cause is believed to be due to dry joints on the regulators at back of the gauges.
This fault makes the car unfit to drive,
and should be replaced Free of charge as a recall irrespective of warrantee.
It is the Octavia mark one.
and is Irrespective of mileage or age of the car, as they should last the life of the vechile.
Sign petition below:
(by voting YES you have signed) - dont forget to post details of your car.
Chris Smith - (Felicia Racer)
Edited by Felicia racer
  • Replies 68
  • Views 11.4k
I've sent skoda an EMAIL.
Basically telling them about the fault, with the octavia.
This is the reply I've recieved from skoda.
Dear Mr Smith
Thank you for your recent email. I was sorry to hear of your dissatisfaction, however, you stated "a particular fault on the Octavia". In the first place this has to be directed to your local retailer who are best placed to deal with an issue. They know who to contact should this be an issue and we can then resolve with the owner.
Yours Sincerely
Christine Massey
Škoda UK Customer Services
08457 745 745 ext 63103
E Mail: [email protected]
Volkswagen Group United Kingdom Limited
Registered Office: Yeomans Drive, Blakelands, Milton Keynes, MK14 5AN Registered in England No: 514809.
My Octavia is a
1.9 TDI
AMBIENT
T REG 98/99
1999 Octavia SLX Tdi failed approx 18 months ago at about 125000 miles. I have removed fuse 15 because cost of repair is prohibitive on a car of this age/value.
2000 Octavia SLX Tdi failed about 6 months ago
Not a dig or anything but its spelt
Warranty
not
warrantee.
Just might look a bit more professional if its spelt correctly. Anyway, good luck with getting this sorted. :thumbup:
Not suffered yet (2001), and judging from the comments here, it seems to be the older cars, so maybe mine will fail in a few months time :-(
Briskoda (freedom member) Soviet Mk 1 Skoda LX 1600 year 2002 ('x' register) Engine type AEE
Faulty dashpod/instrument type 1U2919034A Thank you.
skoda octavia GLXi 1,6 2000, had the problem a year ago, been running without the fuse num 15 since then.
1999 1.6LX Octavia. Had to remove fuse 15 some time ago. This resolves the problem for the majority of the time, although it does reappear occasionally, even with the fuse removed. The car has also done less than 75K miles at the time of writing.
1999 Octavia 1.6 Estate
  • 4 weeks later...
still having intermittant fault
skoda octavia 1.9 sdi slx estate
x reg 2000
graham starkie
1999 T 1.6 Auto GLXi,
Total failure of speed, revs, fuel and engine temp.
Removal of fuse 15 gets the guages working again with the caveats above.
Edited by mannyo
bump
I intend to present this information asap to another local skoda dealer.
Please could everybody who has had the problem vote yes.
(if you have voted no, why is this? mark 2 octavia? - It would be interesting to know what cars are NOT affected)
I voted no and I think most vRS owners also voted no so I think it's just the 1.6, TDI and SDI models.
has the VRS got a different dash?
It has actually now i think about it...
Humm could someone who has access to a parts phish tell us if its a different part no. for the regulator. For the vRS model and the others.
VAG-Cat has 6 different part numbers for the whole gauge unit:
1U1919034Q Left hand drive AMD
1U1919034S Left hand drive AEE
1U1919034T Left hand drive AEE for vehicles with a multifunction indicator
1U2919034Q Right hand drive AMD
1U2919034S Right hand drive AEE
1U2919034T Right hand drive AEE for vehicles with a multifunction indicator
*Edit* I just noticed that earlier models (pre-facelift) have even more part numbers for the gauge unit
Edited by chicken_eyebrow
I voted no (vRS owner) and also my car appears to be a little younger than other posting 2003 (53 plate).
The above 6 part numbers were for 2002 models
The following list is for older 1998-1999 models (these would seem to be the ones most affected)
Neither of these lists mention the AUQ engine which is what's in the vRS.
1U1919034 dash panel insert lhd / AMD (1.4 8v)
1U2919034 dash panel insert rhd / AMD (1.4 8v)
1U1919033A dash panel insert / F >> 1U-W-133 668 lhd / AEE (1.6 8v 75 ps version)
1U1919034A dash panel insert / F 1U-X-133 669>> lhd / AEE (1.6 8v 75 ps version)
1U2919033A dash panel insert / F >> 1U-W-133 668 rhd / AEE (1.6 8v 75 ps version)
1U2919034A dash panel insert / F 1U-X-133 669>> rhd / AEE (1.6 8v 75 ps version)
1U1919033L dash panel insert / for vehicles with multi function indicator / F >> 1U-W-133 668 lhd / AEE (1.6 8v 75 ps version)
1U1919034L dash panel insert / for vehicles with multi function indicator / F 1U-X-133 669>> lhd / AEE (1.6 8v 75 ps version)
1U2919033L dash panel insert / for vehicles with multi function indicator / F >> 1U-W-133 668 rhd / AEE (1.6 8v 75 ps version)
1U2919034L dash panel insert / for vehicles with multi function indicator / F 1U-X-133 669>> rhd / AEE (1.6 8v 75 ps version)
1U1919033C dash panel insert / for vehicles with multi function indicator / F >> 1U-W-133 668 lhd / AGN (1.8 20v),AGU automatic (1.8 20vT): AEH,AKL (1.6 8v 100ps version)
1U1919034C dash panel insert / for vehicles with multi function indicator / F 1U-X-133 669>> 1U-X-228 000* / F 1U-X-133 669>> lhd / AGN (1.8 20v),AGU automatic (1.8 20vT): AEH,AKL (1.6 8v 100ps version)
1U2919033C dash panel insert / for vehicles with multi function indicator / F >> 1U-W-133 668 rhd / AGN (1.8 20v),AGU automatic (1.8 20vT): AEH,AKL (1.6 8v 100ps version)
1U2919034C dash panel insert / for vehicles with multi function indicator / F 1U-X-133 669>> 1U-X-228 000* / F 1U-X-133 669>> rhd / AGN (1.8 20v),AGU automatic (1.8 20vT): AEH,AKL (1.6 8v 100ps version)
1U1919034B dash panel insert / for vehicles with multi function indicator lhd / AQY (2.0 8v),ARZ (1.8 20vT) ,ATF AZH (2.0 8v)
1U2919034B dash panel insert / for vehicles with multi function indicator rhd / AQY (2.0 8v),ARZ (1.8 20vT) ,ATF AZH (2.0 8v)
1U1919033G dash panel insert / for vehicles with multi function indicator / F >> 1U-W-133 668 lhd / AGR (1.9 Tdi 8v 90),AHF (1.9 Tdi 8v 110)
1U1919034G dash panel insert / for vehicles with multi function indicator / F 1U-X-133 669>> lhd / AGR (1.9 Tdi 8v 90),AHF,ASV (1.9 Tdi 8v 110)
1U2919034G dash panel insert / for vehicles with multi function indicator / F 1U-X-133 669>> rhd / AGR (1.9 Tdi 8v 90),AHF,ASV (1.9 Tdi 8v 110)
1U1919034D dash panel insert / for vehicles with multi function indicator / for vehicles with esp lhd / AGR (1.9 Tdi 8v 90),AHF,ASV (1.9 Tdi 8v 110)
1U2919034D dash panel insert / for vehicles with multi function indicator / for vehicles with esp rhd / AGR (1.9 Tdi 8v 90),AHF,ASV (1.9 Tdi 8v 110)
1U2919033G dash panel insert / for vehicles with multi function indicator / F >> 1U-W-133 668 rhd / AGR (1.9 Tdi 8v 90),AHF (1.9 Tdi 8v 110)
1U1919033E dash panel insert / F >> 1U-W-133 668 lhd / AGP (1.9 8v Sdi)
1U1919034E dash panel insert / F 1U-X-133 669>> lhd / AGP (1.9 8v Sdi)
1U2919033E dash panel insert / F >> 1U-W-133 668 rhd / AGP (1.9 8v Sdi)
1U2919034E dash panel insert / F 1U-X-133 669>> rhd / AGP (1.9 8v Sdi)
1U1919033M dash panel insert / for vehicles with multi function indicator / F >> 1U-W-133 668 lhd / AGP (1.9 8v Sdi)
1U1919034M dash panel insert / for vehicles with multi function indicator / F 1U-X-133 669>> lhd / AGP (1.9 8v Sdi)
1U2919033M dash panel insert / for vehicles with multi function indicator / F >> 1U-W-133 668 rhd / AGP (1.9 8v Sdi)
1U2919034M dash panel insert / for vehicles with multi function indicator / F 1U-X-133 669>> rhd / AGP (1.9 8v Sdi)
1U1919034H dash panel insert / F 1U-X-133 669>> lhd / AEH,AKL (1.6 8v 100ps version)
1U2919034H dash panel insert / F 1U-X-133 669>> rhd / AEH,AKL (1.6 8v 100ps version)
1U1919033J dash panel insert / for vehicles with multi function indicator / F >> 1U-W-133 668 lhd / AEH,AKL (1.6 8v 100ps version)
1U1919034J dash panel insert / for vehicles with multi function indicator / F 1U-X-133 669>> lhd / AEH,AKL (1.6 8v 100ps version)
1U2919033J dash panel insert / for vehicles with multi function indicator / F >> 1U-W-133 668 rhd / AEH,AKL (1.6 8v 100ps version)
1U2919034J dash panel insert / for vehicles with multi function indicator / F 1U-X-133 669>> rhd / AEH,AKL (1.6 8v 100ps version)
No problems in the time I owned my 05 plate Mk I Octy vRS Estate (ax 16 months from new)
Thank you.
Thats actually the information we've been needing, and will back up our findings. (with the NO votes)
Could someone record the gauges not working? in a video please?
Hi chicken_eyebrow,
I am wondering here where is the source of information for this. Where are you finding all dash panel numbers here?
I would really like to know of this.
Thank you
Soviet;):thumbup::)
Hi chicken_eyebrow,
Thank you
Soviet;):thumbup::)
Hi chicken_eyebrow,
I have found information here now, and have done registration with Vag Cat. I know now where this information is coming from, and so I say thank you.
Thank you
Regards for you
Soviet:):thumbup:
Yep, you've found VAG-Cat :thumbup: I've been using it a lot recently as needed part numbers for bits when my car got damaged. I don't think all of those part numbers are affected but if the people on here who do have the problem can look up their car on the list and make a note of the part number it would narrow down which part numbers are the right ones for the affected dash units.
I read many moons ago about this same problem and the following was posted on this forum, don't know if it is of any help but it hows the modules that are the cause of the problem.
http://www.infineon.com/dgdl/TLE4276_DS_27.pdf?folderId=db3a304314dca3890115039cf70d0bf0&fileId=db3a30431936bc4b011975fcdb4017d8
Hi hussarman,
Thank you for this link as put I did post this one before. Some one on Briskoda was saying that regulators are cause of fault but this was never confirmed here, and I was not finding this either, and no one has ever found fault with instrument panel yet I think, and not regulators either here.
I did posting of Regulator details that you find here, to be of help for other guys, who were looking for fault here. Ideas here have been connectors, board print, componant electrical breakdown. I am thinking that it is componant electrical breakdown, but schematic is not availiable, and the panel access to do the faulting work is not so good, and so I did not find the fault here. My one before I retire, was higher technical officer, electronics/computing and I know about all this stuff, and so I made test rig, for the problem, but could not track the fault.
I think that first I did the cure for the problem with the back panel connectors, but the problem happened again, and so I did the replacement of panel from salvage yard for £50, and then had dealer do ECU recode here.
I replace panel 1U2919034A with one 1U2919034B which is meaning now that speedo is reading 10 MPH more than speed that I go, and extra 1,500 millage on odo meter. But this is not problems for me, now.
I think that the only solving of the problem, will be Skoda Company, or Felicia racer taking problems to TVs watchdog, as he is saying here.
Thank you for trying to help with this.
Regards for you
Soviet:rolleyes::):thumbup:
