Gearbox Oil ?
just wondering if Skoda use very specific gearbox oils
i know at work, Renault, we only use Elf oils and we have a table of which box uses which oil
a lot of the oil application guides online say 'Refer To Dealer'
Edited by BRUN
Gearbox oil G 052 171 … SAE 70W75 Synthetic.
is that a part number or a type code ?
Moggytech, i'm sure its 75w90 , thats what i put in mine
ive never seen a 70W75 box oil anywhere before so i was wondering, a quick google though says G052171 is 70W75 though......so if it is then its a pretty specific box oil they take
Gearbox oil G 005 100 …
SAE 75W90 (synthetic oil) for FJW box
Gearbox oil G 052
171 … SAE 70W75
(synthetic oil) for FSM HDS box
Service interval "Filled For Life" but they don't say whos life :rofl:
All above boxes are the 0A8 6 speed.
so what box do i have in my 53 plate vRS ?
Check the gearbox information stamped into the casing.
I've got a 2004 53-plate and I'm sure I replaced the gearbox oil with 75w90 at 67,000.
Give Skoda parts a quick ring with your reg no. to find out for sure.
I put in motorquip's own branded stuff cause it was nearly half the price of the VAG stuff. VAG were charging £11 for half litre bottles - feck that right off! Daylight robbery!
that is expensive, but not compared to the price of a new box :)
im only enquiring in case i need a top up
yep understood these things are handy to know...
Tbh I wouldn't have thought the oil will ever need topping up though
probably not but it needs to be checked at the service im having done a week on friday, otherwise my aftermarket warranty will be void
im told i have a HDS box, and the listed fluid is G052157A2 which is a 75W-90 and is £19.73+vat per litre
tried another dealer and im now told its G060726A
damn this topic has just made it harder for me to buy oil lol
I was aware that it was 75w-90 fully synthetic that the gearbox took but if there are 2 different types I better phone up skoda and check what mines is
thank you Ross for clearing up the confusion
Well i've tried..lol
well, Ross has come up with the same number as my local TPS, however the dealer in Preston gave me a different part number, even after checking against my reg
Ross i presume that is a parts catalogue you have used ?...........is it up to date ?
any ideas what the second number i got was for ?
Yep its ETKA and is up to date.
There is no A but A2 is five speed gearbox oil.
but mines a 6 speed, so is it not correct ?
The information I gave was from Skoda Service Manual for 6 speed box. However, oil specs are often updated. I would go with the G052512A 75/90W Synthetic as it has a broader viscosity range.
Strange that different dealers have conflicting information.
Conflicting information or the inability to tell between a five or six speed gearbox.
This thread is hard work..lol
