engine/turbo missing ????
Hi !!!!
Ive just bought an octavia VRS on a 54 plate a week ago,there is a splutter bettween 1000rpm and 3000rpm as you are putting your foot down(basiclay feels like its missfireing? mainly in gears 2,3 and 4.But then the car takes off like a rocket after 3000rpm and is very fast !!! ive just had a full service including cam belt change done at the skoda dealers thinking it would sort it out but i still have this splutter/missfire between 1000rpm and 3000rpm .
is this normal or can someone help me please and tell me what the problem is...
Cheers !!!! Lee
Hello and welcome Lee :D
That aint normal but if you post your question on the forum for your vrs i'm sure somebody will be able to help. Good luck :thumbup:
Welcome. Hope you get it sorted.
Hi, you probably want to visit the VAG-COM forum too. Welcome!
could be a number of things but the most likely is simple a very dirty throttle body give it a good clean..
also maybe coilpacks on there way out....
welcome to the forum
try cleaning the throttle body first:thumbup:
Hi there
stug71 said the same but i thought i had posted this on the forum ?? what have i posted this on like please,probs sound quite thick like i know but am new to this....Thanks !!!!!!!!!!!!
Hi !!!
thanks for that info westallc !!! ive read through lots of pages and seems a lot of people are saying coilpacks to the problem i have,will give both a try i think....thanks
:+1:
...as says, ask in the Octavia forum! :thumbup:
When I read the subject... I expected to be reading a thread about someone buying a car & discovering it had no engine or turbo in! :rofl:
Welcome aboard! :)
Simbo99 you is funny :D and awfully helpfull to :D.
Welcome to Briskoda
Cheers simbo99 !!!!!! i used the link to the octavia mark1 forums and have just read through 70 posts in the last hour and got **** loads of very usefull info !!! looks like im going to save a lot of money on this one.........Cheers again mate for the help
Hi !!!
I just found some quality pics and step by step info off user chicken_eyebrow on how to clean out a throtle body !!!!! going to tackle my tomorrow and hopefully it sorts out my splutter.....Im getting used to this forum site now:thumbup::thumbup:
Hi !!!
cleaned my throttle body out today but car is still spluttering at 3000rpm ???? dealer said the other week that the coil packs would of been picked up in the service if they were faulty ??? not sure what to try next.Think i might just live with it...
Anybody got any other idears ???
CHEERS !!!!!! LEE
I have a similar problem, but at lower revs.
Cleaned my TB today, but tbh it was remarkably clean anyway (the car has only done 42k)
I'm thinking coil packs or the wiring to the coil packs... (have you tried checking the wiring yet?)
iirc you lift the small cover off the battery and disconnect the big wires one at a time with the engine on tickover - if there's a problem the engine note will change noticeably on the coilpack/wiring where the fault is..
Be interested to know how you get on...:D
Hi
i put me car into the skoda dealer for a full servive thinking it would clear it,when i got it back i complaind and the dealer checked it again and again,they said the coilpacks or wiring would of showed up on there diognostic machine as i mentioned it to them from the info off here so im sure thats all ok.
trying other things at the min and will post my results on here of things ive tried even if they fail.... Cheers lee !!!!!!!
  • 4 weeks later...
Hi
What have you found? I have this problem. Going to try cleaning Tb first, then coilpacks.
  • 4 weeks later...
Hi there !!!!
Its been a while but my car is finaly sorted after trying many things,problem turned out to be a split hose....the hose was sittuated right behind the manifold and was very awkward to get to apperently.the hose was quite small,approx 200mm in length and approx 10mm diameter.
YOU COULD ONLY TELL THE HOSE WAS SPLIT WHEN IT WAS OFF AND IN YOUR HAND AND YOU BENT IT,IT LOOKED PERFECTLY NORMAL OTHERWISE !!!!
The car is running as sweet as a nut now and its thanks to the garage i put it in called Vee-dubs located in Bill quay ,tyne & wear in the north east and only cost me £30
HAPPY DAYS !!!!!!!!!!!!!!!
welcome
