These RARB's then......
though i have come from a Clio Williams setup, which can out handle a LOT of other cars lol
You'll know what I'm talking about, then - courtesy of 'pietroz' ( :o ):
Although to add my name to those whose wish was simply to inform rather than terrify, you'll notice that while the inside rear has lifted slightly, the car's not swapped ends or anything... :thumbup:
  • Replies 79
  • Views 5.2k
Oh it's all good fun in the Clios :D
Steve
Surely that clio's way too soft at the front to lift that high?
But just to add to the photos...
Completely standard rear beam & ARB. Just absolutely no droop in the suspension leg to make it act like an ARB :)
It's a bit of a trick that photo from Evo, to be fair. It's down on the Betys-y-Coed road, Evo triangle territory, and there's quite a bit of camber as you come onto the road, and a dip beforehand - so if you turn-in, in a particular way - that's the result :)
Still, quite a stiffly setup little car :)
Steve
the rear wheel may lift, but the back end doesnt step out :)
