BioNAV
I think that thats the best version, but am i the only one that prefers it? :D
Yes we already knew you prefered that :rofl:
The word ****** springs to mind :finger:
:rofl:
How do you get the BioNAV to work? Mine must have a malfunction. All I get from it is a load of gobledegook, certainly no directions! :rolleyes:
Gently press the button just above the pink input/output socket and you will find the Bionav is much more compliant....just dont forget to spend time familiarising yourself with the 2 larger modules up top before attempting to find the pink button...malfunction could occur resulting in system failure and non compliance. :thumbup:
Ah, now that sounds simple enough. ;) Will give it a try tonight! :D
My knowledge of the fabia vRS is limited but I do have many years experience in handling/using BioNav units. I would suggest that reading the instruction manual ( if you did not get one with your unit they can be obtained from any good book shop ) would be a good idea because many of the posted problems could easily be avoided. A damaged unit could be costly and time consuming to repair.
PMSL!!!
:rofl:
