Common "issues" and solutions with Felicia/Favorit based vehicles
On 10/08/2021 at 12:23, D.FYLAKTOS said:
20191029141346_hb_body_950_pissa_se_spre
Tar spray won't help?
That is worse as it will encapsulate any rust and make it propagate very fast
  • Replies 53
  • Views 117.1k
  • Wet footwells / under dash area Often caused by water getting in through the windscreen seal. Use lots of sealant and have a riot squirting it into every nook and cranny you can with the windscreen
  • Typical cooling system failures 1. The engine does not reach a temperature of approx. 90 C faulty thermostat - the bracket cracks causing a large circulation permanently. The engine temperature the
  • Possible signs of a failed head gasket Note: some of the symptoms could be attributed to other parts failure too   1. Cooling system related constant overheating excessive pressure - constant bu
Some guys use it.
No he is using oil based which is fine.
Not tar based
As far as the sika is concerned those products are for professionals and have to be applied properly
Edited by Thefeliciahacker
  • 4 weeks later...
On 11/11/2009 at 11:11, TeflonTom said:
coolant temperature sensor.
common problem is coolant temperature sensor failing, sometimes manifests itself as making the car difficult to start when it's hot (especially on diesels), also may cause an erratic temperature guage. sensor can be removed by squeezing the spring clip to take off the plug, pull out a plastic retaining clip, then lever out the sensor with an old screwdriver or similar. you will loose some coolant in this process so be careful that you dont get scalded by hot coolant too. it is worth replacing the rubber o-ring at the same time and this is normally supplied with the sensor. essentially all it is pair of thermistors (resistor which is sensitive to heat) housed in the same unit, one part is for the temp guage, and the other is for the ecu
http://i86.photobucket.com/albums/k97/teflontom/coolantsensor.jpg
sensor location 1.6 petrol engine
http://i251.photobucket.com/albums/gg299/philje123/Nelly/P1000928.jpg
sensor location 1.3 spi engine... thanks to philje123 for this picture
http://i86.photobucket.com/albums/k97/teflontom/dieseltempsensor.jpg
sensor location 1.9 diesel engine... thanks to AndyIoW for this picture
pin-out (1.6 petrol)
1. goes to ecu (pin 42)
2. goes to dash loom for temperature guage in insrument cluster
3. earth for ecu sensor
4. earth for guage sensor
pin-out (1.9 diesel)
1. earth for ecu sensor
2. earth for guage
3. to ecu pin 3
4. to temperature guage
pin-out (1.3 spi and 1.3 mpi)
2. earth for guage sensor
3. to ecu (pin 53 on mpi, pin 42 via air temp sensor on spi)
4. to temp guage
if you have access to a multimeter, typically you should get around 300 ohms across the sensor when the engine is at normal operating temperature. and approx 4k ohms when cold...
if anybody has a pic of the location of the sensors on the others i'll add them on
Hi Tom.
Whats temperature sensor back inlet manifold and number wite on ecu ?
Have same resistance ohms that you describe  ?
Regards
