8J x 18 et35
Recently i bought a new rims for my fabia RS. I bought Rial Nogaro 8j X 18 et 35. I am wondering if this rims will fit to my fabia without any problems? I was thiking of lowering with H&R -40mm, not lower than that?
http://www.grande-punto.de/attachment.php?attachmentid=37
best regards from Slovenia
18"s dont really work on the Fabia at all, because the tyre profile needed to maintain an accurate speedo will be like rubber bands wrapped around your wheel which will badly upset handling (225/30 18).
i was thinking of 215/35/18 tyres
or even 205/35/18. Will look alot better and with the little bit of stretch minimise any rubbing you might get.
That might work ok, although you would need to check that the stretch introduced by fitting that size tyre will not compromise the safety of your car given the very low profile. I have an 8J wheel on my car and even a 225 wide tyre already has a small degree of stretch.
http://www.tyrestretch.com/8_215_35_R18/
