Fitting a Boost Gauge MK1 VRS
Hi does anyone know how to fit a boost gauge in a MK1 OCTAVIA VRS? Ive searched but not found anything for the octavia.Im not really bothered about the inside of the car its the fitting of the boost pipe under the bonnet that i need to know...many thanks.
  • Replies 96
  • Views 30.3k
  • I take it the feed is just for the light? with no electric will the gauge still work? Can you get a single pod to go bellow the stereo? I can only find a 3 pod version.
  • RobClubley
    RobClubley
    Damn work gets in the way of car modding I was working from home today and itching to nip down to the garage to finish off my sub box.
  • how can i get it to have constant power? what soo that means i have to have it all even wen the car is turn off?
put a t piece in to the pipe on the fuel regulater thats under the engine cover near the injection inlet on your right. thats wat i did :thumbup:
I bought a liquid gauge. No pipes. Just plugs into the diagnostics port. Does all sorts of other readings, plus g force, fault readings, throttle body reset etc. Quite pricey, but I'm well impressed.
have u a pic please?
If you care to use the search,this has been covered many times,and there is a nice guide with pics from rob.
i HAVE searched but cant find link...can someone post it on here please thanks.
the liquid guage isnt the best if im honest should stick with aboost gauge on its own.
liguid guage good for the first few weeks but relies on to many things being perfect to get good readings...
Yay, my famous big arrow pic :D
Rob you should be on commission with those pic's, :D:D Must be the best fitting guide for gauges on the net. B)
The liquid gauge uses the OEM pressure sensor which measures total pressure ie; static pressure + intake air velocity.
Taking a boost reading from the fuel pressure regulator will only give a static pressure reading, which will be less than total pressure.
I dont agree with your comments about the liquid gauge.... they display real time boost and peak boost levels at the same time, from the same sensor the engine ECU is using, which has got to be better than using a non-calibrated mech or electrical boost gauge.
And as for connecting into the FPR pipework......well that is simply wrong, wrong wrong :rofl:
can anyone describe where and how you get power to the gauge, I like the idea or having a boost gauge but am not 100% sure on how to do it. I'm half tempted to pay someone to do it for me. Anyone on here fancy doing it?
use your head light switch on your right of the steering wheel under the air vent.......pull it out tilt it down and on your right end of the plug
the wires theres a brown one thats earth...go a long the same line of the wires to your left and the end one is live...the live will only work when you use your side or mine lights hope that helps
okay fella but as i had this in the octy first and was using it real time i wasnt impressed witht the unit to small and a bit of a gimic if you ask me thats why i sold it after a couple of months..
weak maf = strange readings
Edited by westallc
I'm a little bit more interested in the "wrong, wrong" part :D. I know a LOT of people who have it hooked up this way...all of them wrong?
where would you get an electric feed so it ran all the time, not just when the lights are on?
I took a feed from the switched live to the head unit.
Yeah there's nothing wrong with tapping off the FPR line. No issues arise from doing this.
You can't beat the instantaneous accuracy of a mechanical pressure guage.
  • 5 months later...
hi guys im new on here can any 1 help me ive jus fited a boost gauge to my skoda octavia vrs everything is all connected but all it does is light up so something is wrong plz can sum1 help me
Can you give more details? Pics of how you plumbed it in?
Cheers.
Cheers.
well i cnt give u pics at the mo because im at work lol but i cnt work it out i found info on how to fit from this website and i followed ur pictures aswell well my dad fited it 4 me its lighting up but it wont move
ive fited it the way u have done ur the t piece is connected on t to the fuel pressure regulator. and the is all connected to the ignition so wen u turn ignitio on the gauge comes on its really doing my head in
Was it working before? Could just be a bad join to the sensor, or a wire not joined some gauges have one wire for the light and another for the gauge it's self
