Lowered Fabia's & The Engine Undertray ...
Re. Fitted my engine undertray tonight .....
Seing as the Fabia Engine undertray is already quite low to the ground in standard trim... What have all you folks done that have lowered your fabia's ??
If it wasn't for the Bulbous bit there would be a decent Gap between it & the road.
The lowest point on my undertray is probably approx 2.5 to 3 Inches Inches off the tarmac, My sump is reinforced but just wondered what everyone else has done .. Whether you have removed all together ? Left in place ? & if so, how does it fair with those Orrible Speed Humps, The one's that are just random lumps of Tarmac or concrete & don't straddle the whole of the road ..
Cheers.
Dean
I recently took mine off at it really started to **** me off, catching on rabbits, ice rocks etc.
I plan on getting a metal totally flat one made up by one of the guys here to replace it.
Leave it as an early warning device, you know you need to slow down when it scrubs! :)
^^ what he said
All the way down on coil overs without removing adjusters or helper springs and my under tray is fine
It does catch sometimes on speed bumps and stuff on the road but it's nothing major. Only other issue I've had is during all the snow, it did not like the snow in the middle of some of the roads I had to drive one bit lol or the end of my driveway with the snow
Left mine on, Admittedly a few mounting points are now battered, and aided with cable ties.
But i'd prefer that to scrape on anything first.. What i have noticed is im slowly wearing away the little flaps that come down in front of the wheels from the bumper...
Kev
Mine got ripped off :(
Kev
Yours Must be lower than mine then :D I have not started to wear those bits yet .. Sometimes the cupra front splitter gets a Rub on multi storey Jobeys ... :D
I'll leave it on then & see what occurs .... Although after fitting it .. What do i do tonight !!! Drop a Flinkin spanner down there, which promptly vanished from sight ..... :giggle:
Cheers.
Dean
Edited by dfullb
mine didnt last long either :( i catch the wish bones i think it is sometimes, but not the sump yet. My LCR Splitter is mullered :( come off the a5 and it was dragging touring car stylee :rofl:
i had no choice but to remove mine, as you can see in the picture there is no clearance at all with it fitted.
Hello Sump Assassin,
Good grief that is SCARY LOW, to think your oil pan is only about another 2inches higher, you certainly like to live life on the edge. LOL
Edited by giandougl
i left a little bit of room for error with mine :rofl:
