updated..code 16885 16946..
driving home to nite and the lights started to dim and engine was trying to cut out then the battrey light stayed on .......could this be altornator? thanks
Edited by vrsjaw
i did code and one stays low volt.....i did smell abit of a burning plastic but not bad that was half a hour before i broke down? av check on here and people have had probs with a lead that goes from bat to alternator? thanks
Edited by vrsjaw
Check the fuse holder on top of the battery, been some posts on here about it overheating and melting the plastic. And if you can have a look at the cable between the alternator and battery, if the connections at the alternator end look corroded or anything disconnect the cable and give it all a clean with a wire brush or similar. Have you tested the battery yet?
right i was looking at the car to day and the wire on top of the battrey that goes to the alternator has melted.....av cleaned the wire end that goes in that box on top of the battrey and when i jumped started my car after fitting this wire back it seem to be getting very hot.....so will i need to change this full wire? av added a pic and plz could some help as i dont no wat to do ......any info and part numbers for this full wire would be bgreat full.....thanks
Edited by vrsjaw
This thread should help
http://briskoda.net/forums/topic/154294-fuse-holder-overheat/page__p__1913794__hl__fuse%20melted__fromsearch__1entry1913794
I think the problem lies in the connector on the end of the cable getting dirty and providing too much resistance so the cable overheats near the end. The whole cable should be replaced... and it looks in this case like the metal slot in the fusebox that the cable fits into too.
Edited by chicken_eyebrow
av ordered new lead and the fuse box that sits on top of battrey..78gbp.......i just hope my alternator is ok...thanks for the help
av took the cable off and sames to look ok....am picking the new parts up to morrow......could the alternator be the problum and caursed this...thanks
The black cable in the picture,the crimp is fooked,would need to be recrimped or fit new cable (which see youve ordered).Once this is fitted with new fuse box all should be well.
i hope so buddy....as the alternator is 136 to buy.......but i mite have to buy one....thanks
fitted new cable and fuse box seems to be ok at mo and its chargeing battrey.....but i have this code 18010 P1602 Power Supply (B+) Terminal 30 Low Voltage...and i need my stereo code.................thanks
That fault code just means the battery has been disconnected and re-connected. If you clear the code it won't come back. Worried me the first time I did it on mine I wondered what I'd done!!!
Can't help with the stereo code unfortunately, if you don't have it written in the stereo manual then a dealer might be able to look it up for you but they can charge 20 or 30 quid for it :thumbdown: . Once you've unlocked it, there's a setting on the stereo menu that you can choose so when it loses power it won't ask for a code to unlock it again.
if yours is a 2001 you shouldn't need the code if it is the original radio. there is a sequence that gets it to work by comparing the radio against the value stored on the ecu. I have done it before but cant remember the process. I will have a dig through my posts now.
Edit: found this http://briskoda.net/forums/topic/89068-symphony-radio-code/page__p__1761193__hl__radio%20code__fromsearch__1entry1761193
HTH
Edited by karlbar2k
stereo ok now......it came back on.......thanks
