Post mortem of blown hybrid turbo
Took apart the hybrid turbo today - more out of morbid curiosity than anything else. :D
The turbo.....
The VNT mechanism (was quite clean)
The input side - Quite a lot of play in that wheel....
SNAP! PING! BOOOOOOM!
Another part
I don't see anything wrong with this wheel?! :giggle:
Is that 4th shot down supposed to be your compressor wheel? :o
It's the reverse side of the last photo. :) And shows where the shaft snapped and why the hot side compressor made it's way down my exhaust. :D Never to be seen again. :giggle:
Looks expensive Jason, but at least you have it running again :)
can I make an observation about this photo, I believe there should be a nut on the end of that threaded shaft, could the fact that the hotside impellor was insecure be the cause of the turbo failure
Don't think I will ever know but it went from hero to zero in a nanosecond so whatever happened, happened quickly and spectacularly. :giggle:
yeah there's deffo a nut missing off that, might have caused the impeller to float slightly.... question is, where is the nut now?
on a certain one way toll road in Germany ? :giggle:
Ah well, at least you broke it in style!
Thats the fun bit, guessing :rofl:
This was what I found in my boost pipework.
and the cold side had well and truly detatched itself.
