Bluetooth Function in 2010 FL
I've heard that the iPhone is not compatible with the Bluetooth included in the FL Octavia.
Anyone have a list of the actual phones that work with it?
Thanks!
Here's an extract from the brochure (dated 1/2010), not sure if anyone has a more up to date list which might include the iPhone?:
Mobile phones compatible with the Bluetooth® system
BenQ Siemens CX75 BenQ Siemens EL71 BenQ Siemens M75 BenQ Siemens M81 BenQ Siemens S55 BenQ Siemens S65 BenQ Siemens S68 BenQ Siemens S75
BenQ Siemens S88 BenQ Siemens SK65 BenQ Siemens SL75 BenQ Siemens SP65
Motorola RAZR V3 Motorola RAZR V3i Motorola Q9 Motorola V3635 Motorola V551 Motorola V635
Nokia 3109 Nokia 3110c Nokia 5200 Nokia 5300 Nokia 6021 Nokia 6131 Nokia 6151 Nokia 6230 Nokia 6230i Nokia 6233 Nokia 6234 Nokia 6280 Nokia 6288 Nokia 6300
Nokia 6500 classic Nokia 6500 slide Nokia 6810 Nokia 6820 Nokia 6822 Nokia 8800 Nokia 6230i Nokia E51-1 Nokia E51-2 Nokia E71 Nokia E90-1
Samsung D900 Samsung E250 Samsung E590
SonyEricsson K510 SonyEricsson K510i SonyEricsson K530i SonyEricsson K550i SonyEricsson K600i SonyEricsson K610i SonyEricsson K700i SonyEricsson K750i
SonyEricsson K770i SonyEricsson K790i SonyEricsson K800i SonyEricsson K810i SonyEricsson M600i SonyEricsson P1i SonyEricsson P990i SonyEricsson S500i
SonyEricsson T650i SonyEricsson W550i SonyEricsson W580i SonyEricsson W660i SonyEricsson W700i SonyEricsson W800i SonyEricsson W810i SonyEricsson W880i
SonyEricsson W900i SonyEricsson W910i SonyEricsson W950i SonyEricsson Z610i SonyEricsson Z710i
T-Mobile MDA Vario2
Mobile phones on the ‘3’ network are incompatible with the Bluetooth® phone preparation on Octavia.
Thanks!
Thanks!
Basically, if your phone has the rsap bluetooth profile (or in the case of some Windows mobile phones, add on software is available) it will probably work with the GSM III bluetooth kit in the FL Octavia.
The older GSM II kit uses the handsfree profile rather than the rsap profile and is compatible with almost every bluettoth phone known to man... This can be retrofitted if required.
I'm not a mobile phone power user, but neither my Sony Ericsson Z610i or LG Cookie 500 worked with the factory fit Bluetooth.
It found them alright, but said they were incompatible.
The Z610i is on the list so I don't know what I'm doing wrong.
I'll try me mate's Nokia5800 next week.
I haven't used a Sony Ericsson for a couple of years now, but is there a menu option somewhere to turn on rsap or Remote Sim Mode anywhere?
My mates 5800 had Remote Sim Mode on by default and it works great in his Golf with the GSM III although he has to manually sync the phone book which as far as he's concerned is not a massive problem as it doesn't change that often...
I have a Nokia 5530 which works the same as the 5800 and was paired to his kit at some point in the past... So if you're anywhere near me you're welcome to try that too (No idea where in the Midlands you are...). Maybe between us we can persuade your "compatible phone" to work too :)
Hi Raglits,
I live in N.E.. Coventry area.
I will try the Z610i as there were some manual BT setup options as you suggested.
The LG also has remote SIM mode, I'll have a fiddle.
Hi Raglits,
Walsgrave area by any chance? I'm over the other side (Meriden) until the end of next week when I move back into Brum but am happy to try and help out - can you tell I'm a techie :)
Good luck with the phones, just think though, it could be worse and you could be dealing with the Black Art of wireless networks instead :)
Edited by Raglits
Thanks guys! I have an E51 so I should be safe..!
Cheers Raglits :thumbup:
I enabled the remote sim function on my LG 500 Cookie and now it works a treat with the maxi-dot & Bolero.
This is a dreadfull excuse of a touch screen phone and I actually find it easier to use through the steering wheel controls.
Just need to tidy up my address book & I'll be happy.
E51 works fine, thats what i have.
Glad to hear one of the phones is working... I didn't order the factory bluetooth because I know my iphone doesn't have rsap, had a Fiscon unit fitted the weekend after I picked the car up which works a treat, but the GSM III is a cracking piece of kit if your phone is supported...
Does bluetooth come as standard on the new Octavia Vrs? I assumed it was an option?
It's an option on the DSG and not available to order on the manual. It can be retro fitted though
Howdy, my wife is gettng a new phone today Nokia 5530 and was wondering will it be ok on her 2010 Superb with Bluetooth?
any ideas?
thanks and rgds, Colin
any ideas?
Can't definitivly answer the question but this is the phone ive been looking at and im led to believe it will work wil my forthcoming Octavia bluetooth kit. Please let me know if it does!!
will do once i get it connected up tomorrow. thanks. C
dissapointing bluetooth can only be a factory fit option if you go for DSG.. the Yeti Elegance has it with non-DSG.
My dealer did re-assure me though that retro fit is quick and easy, done through the sunglass holder in the roof and all the wiring is there apparantly which again is baffling as to why a factory option is not possible!
Just a quick heads up. Trying to carry out research into what mobiles have rsap installed so that it will work with the BT Skoda system - not an easy task. Think I have found an up to date list of handsets that will work.
Check here:
http://de.wikipedia.org/wiki/RSAP
might be in German but you get the picture!
Cheers.
You can have bluetooth as a factory fit on a manual Octy, just not the vRS for some insane reason...
