Induction Kit
HI all! Ive been reading the disscusions for a while now and seen that using the intake trumpet from a seat pd160 works well and alot of people are going for the green panel filter but can you get an ionduction kit for the fabia and would the price vs performance gains be worth it? If so where could i source 1 from
:confused:
You can get a K&N 57i induction kit for the Fabia vRS (see there website and search for your vehicle), BMC-CDA kits fit and i beleive someone also has a Dynatwist.
I originally was after an induction kit for my Fab vRS but eventually decided that if anything performance is likley to go down a notch (due to heat soak) so have followed the rest and got a Green Filter and PD160 intake :)
Cheers for the advice did a bit more searching and found for the price of an induction kit i'd be better off spending the money on the larger intake and the green filter. Did you order the uk spec 1 or the euro 1 which is supposed to be larger in diameter? Even read somewhere that someone has order a south african spec 1 which is even larger?????
