Noisy Windows
Morning
Has anybody else got the same issue with all 4 windows, in hot weather the windows on the Vrs are noisy when first closed the creak and pop until the window switch is lifted again and the motor re energized. The problem goes away in cool weather. I've made sure the mech is lubed in the correct areas and the rail is fitting correctly and am now at a loss :think:
a wee bit of silicone spray on the edges of the window runner should cure this
