the lights
im sick of the lights dimming when ever any load is placed on the cars electrical system grr is there any way for them to fix it ????
I cant say i actually notice mine that much.
You allready have a 120 amp alternator. At max pull the PAS pump can draw up to 80 amps so in theroy it shouldn't struggle but theres so much in the way of electronics now that it all adds up.
Drop your carintot he dealer, get them to check your battery condition and the alternator charge rate just to keep your mind at rest. Failing that log a complaint and see if the factory will do anything about it.
Mine only does it when im "dry steering" which isnt often coz i was taught that thats bad when i was learning to drive :D
mine happens as im driving at say the motorway speed limit not 1 mph morewink.gif and i try to raise the windows if they are already up or infact if i lower them tbh everything seems to do it or am i just used to the hids in the clio :(
My lights dim for a second if you try the "just ensuring windows are shut" on the switch.. always has...
it annoys me :( cheap german cars
