What's The "rear Tweeter Trick"?
  • Administrators
In the Octavia, the standard stereo is ok but has some limitations, like the location of the rear tweeters, especially close to the ear for taller drivers.
This can get quite painful and the sound breaks up at surpringly moderate volumes.
To disconnect the tweeters in the hatchback is very straightforward. Open the boot and under the rear speakers there are 2 wires. Simply unplug those wires that are innermost.
In other models access to these wires may not be as straightforward. Therefore, use the following method:
The tweeters are located by the rear electric window switch in the rear passenger doors.
By using a small flat bladed screwdriver, this panel can be gently unclipped and, once inside, the connection plug can be disconnected.
You will now find you can adjust the bias front \ rear more and reach higher volumes with less distortion
  • 2 years later...
Further to this, what I have done is disconnect the factory rear tweaters and replaced the rear speakers not with compnoents but with co-axials. The rear speakers now just bulk up the sound and all the sound stage and majority of the treble comes from the expensive front components. Sounds fantastic.:thumbup:
  • 3 months later...
what speakers did you use in the front ?
To add to this, on the Fabia you can lift the carpet in the boot surrounding the speakers and remove one of the plugs [you will see two plugged in] and this disconnects the rear tweeters.
  • 2 months later...
I have an Octavia sport (a new one) and the stereo is orientated well over to the right and is quite uncomfortable. It doesn't seem to make a great deal of difference what I do. So, I was going to try and disconnect the rear tweeters to see if that helps.
They are by the door handle, so I prised out the window switch (which has the tweeter cover on it), removed the only screw I could see but still couldn't get access to the connections. It is possible to get your finger behind but I am loath to do this in case I damage something.
Does anyone know how to make the stereo more evenly balanced and if it is the tweeter trick, how do I get to the back of the tweeter?
  • 7 months later...
I've got the mk1 one octavia, I tried to remove the outta connection of the two.
It doesn't seem to want to come out, there's a little catch to press in and it should just pull out yea?!!
EDIT: Got them out now, can't say the system sounds much better with them unplugged tho. Guess I need to do some tweaking...
I've done this on my fabia. Found the rear tweeters to be way to close to the front drivers.
  • 4 weeks later...
This may seem a daft question but for cars fitted with rear parking sensors if you disconnect the rear tweeters (driver side mainly) wont the warning beeps be lost?
Am I doomed to have the dodgy teeter blaring into my right ear for good? :eek:
Chris
Chris
No, its a totally different speaker. The tweeter has no connection with the parking sensors.
Awesome!
Thanks Mannyo
good to know as i was wondering why the connectors had two wires in them for each connector. didnt know they were mids n tweeters in the back
i think i will be upgrading them as they are only small cones in the back. im used to 6x9's that my lexus had as stock.
is this the same for octy 2?
update, i cant get to the wires of the rear tweeters in the door and the only option seems to be to take the whole door cover off to get to them, surely their must be an easier way to solve this.
  • 5 months later...
A small section of gaffer/duck/tank tape (cut to size) placed over the tweeter grill muffles the sound nicely! :D
Aaves messing around taking thing to bits, and putting them back sometime.
  • 11 months later...
i did the trick with the tweeters and it did not make much odds. to be honest the stereo in the octy vrs is a bit poo. the only way to get it going is to change the speakers add a sub etc.
NO; change the head unit first!
Agreed... attatck it at SOURCE ;) head unit after all is where the quality originates, also a sub makes sooo much more of a sound stage:thumbup:
  • 9 months later...
Yes the standard head unit has very poor sound quality, replace it with a good aftermarket one. You may well need to get an in line ariel booster as some head units may not power the one in the roof ariel.
  • 1 year later...
I've got a Fabia hatchback and found the rear tweeters in the rear door to be painful in the drivers ears... How do you do this trick for those speakers in question?
