FMIC fitting
Woah, what a bloody fart on that was. How on earth has anyone manage to fit the intercooler from ebay onto there cars??????? Started at 9 finished at 2 and realised it is never going to fit, yet alot of people have it fitted. So had to spend 3 hours putting it back to standard :'(
Are you sending it back or will you sell?
Was It a kit you bought or did you buy seperate components?
jut buy a forge :thumbup:
fitted one in an hour :thumbup:
Rob Clubley bought a kit like this & had fitting problems, so It might be worth having a word with Rob about It :thumbup:
The pipes from the turbo side seem ok, I can get them to fit if i remove the horn, its just going from the throttle body to the intercooler that doesn't seem to fit for some reason.
i seen one of these kits the other day and omg what a pile of crap, like westallc says a forge one, or source the parts in where the intercooler has inlet and outlet on the same side saves alot of messing about
i was going to attempt this ebay route but ive decided to wait and go the forge route :thumbup:
After a long research I have decided to go with forge fmic, it`s just to many things that can go wrong and good end results is not guaranteed according to some DIY-s ...
It is expensive, somewhat overpriced, but it is 100% straight bolt on fmic .... ;)
I've got a toyo sport one on my vrs, looks like a good fit, dunno how hard it was as i brought the car with it already fitted lol
run some logs and i bet its rubarb and the standard sidemount oem worked better
there cheap for a reason
it could be down to a number of things but the main two are incorrect core size and ally with different thermal conductivity
find any cheap one made of the right ally and your onto a winner ;)
email Forge through this site and you will get good discount :thumbup:
At the end of the day people have fitted the DIY route with not too many problem, but if you expect to get a perfect fit and do no reworking of components then only one way to go, get a kit where someone else has done all the design/flow and data of a known working solution.
Yes Forge is dear but hassle free fitting.
