Octavia 312's won't fit on the Polo/fabia vrs chassis?
As the topic says.
maybe someone should make a sticky on this?
but I've been told from a member on here that the octavia 32mm's wont fit on the fabia vrs / polo chassis? why is this?
Cheers.
If you re talking about 5x100 312mm then they will only fit onto Fabia vRS, you require to get the hubs etc from a vRS if it is a lesser model.
Really? I thought as long as you had the 288 setup it was fine?
EDIT: Got beat to it! lol.. ^^^ what he said! :D
Edited by Rob.
Strange, they fitted my Fabia vRS
QUOTE "Car:PD 100 POLO"
Well, that's not based on a fabia vRS is it. ;) That will have the FSIII 256mm front brake setup which cannot have 312s fitted to. You need the PD130 fabia vRS outer hub housings / bearings to be able to fit them. Believe me I know as my car was a pd100 once. :D
