yellow engine light on my dash board
hi my name is bruno i live in london im a proud owner of a fabia but i have a problem me engine shakes alot and a yellow engine light has come up on the dash board any help please thank you
Welcome to the forums, That light is a CEL (Check Engine Light) and when lit usually signifies that a fault has been found and a code will heve been stored in the ECU accordingly, you will need to get someone with diagnostics to check for codes and this will tell you what the problem is, usually a dealer/specialist independant.
Hiya. As above; I'd suggest checking the VAGCom forum to see if there's a member near you who'll can help.
thanks for the advice i will check my local dealer thank you
