pulse wire
can anyone one tell me were the pulse wire is on the new superb am trying to install a taxi meter :smirk: :smirk:
There isn't one. The speed pulse is now transmitted as a digital signal on the CANBUS.
If you want to get access to it, then you need a suitable CANBUS adapter.
I've used this adapter in the past:
http://www.bluespot.co.uk/car-audio.aspx/7607589531-adaptor
but sadly it doesn't seem to be available any more. I'm sure that Autoleads will probably have something that does the job.
I think this would do the job, though:
http://caraudiosecurity.com/shop/product/products_id/8110.html
Andy.
Edited by Bagpuss
http://www.bluespot....7589531-adaptor
http://caraudiosecur...ts_id/8110.html
Andy.
To add to that, my 07 Passat had to be modded to take a lead from the clocks plug to enable the meter to pick up a feed.
When I got my meter fitted the pulse came from behind the dash PIN No 9 I think, If I recall I got the info off this site so just make sure you do a good search.
By the way my meters a HAC
Regards
Paul
