exaust performance gains.
ivd a jetex in the past and it was great quality, if that helps anyone emoticon-0148-yes.gif
If its more sound fruity sound you want, why don't you try the 'mufflerectomy', and get them to use your standard tail pipe? Basically it just removes the backbox from the system which is replaced by a straight pipe, and you can leave the cat in place.
So.. from reading this thread.. Which is better?
Removing cat (Particle filter)
or
Removing back box?
I think removing both will be a bit loud personally.. so that options out :giggle:
or
Removing back box?
Remove the cat for mild gains and very little extra noise.
Remove the backbox for more mild gains (possibly slightly more then removing the cat alone) and MEGA noise increase
Remove both for the best gains and a SUPER loud exhaust and expect your turbo to be working overtime from the complete lose of back pressure... :(
I've got the Jetex on my vRS. It's very well made and did give a small gain
Does it sound any different or was it there when you bought it?
