Best long life oil for variable service?
Which is the best? I know there are lots of differant ones, but which would be the best to use for my Occy VRS, also how many litres do i need for a change?
Cheers.
The various choices available are listed in the Articles section here. As to which is best, your guess is as good as mine. If it helps, I believe that Castrol SLX Longlife II and Shell Helix Ultra X were the first Longlife oils available through VAG dealers, and Fuchs supply the factory fill oil. Autodata CD-2 lists gives the engine oil capacity as 4.5 litres including filter change.
Cheers, i'll go for the Fuchs stuff then :)
It's the stuff they use at the factory, so at least you know it won't Fuchs up your engine :D
LOL, so do they use the 0-30 or 10-40 stuff?
