Skoda Octavia Starter Motor
Hi all,
New to Briskoda, great site. Have been driving skodas for last decade. Currently have a 2005 diesel Octavia. A bit sluggish starting recently. Garage diagnosed 2 faulty glow plugs and a temp sensor. All replaced. However I am now also told the starter motor is slow to start and may give up in a matter of months. Doesn't sound particularly bad, only a bit sluggish when starting warm, which I'm told is common. Wondering whether this is normal, and would I get any indication when starter is about to give up the ghost. Also, how long is the lifespan for a starter motor in the Octavia.? Approx 88,000 km/55000Miles on clock. Any advice would be greatly appreciated.
  • 4 weeks later...
Hi all,
If it's still on its original battery then that may be getting tired now and need replacing. My 2.0 Tdi started getting sluggish on start-up last winter so I decided to fit a new battery and found the original one was the wrong size (lower capacity than it should have been - 61 ah instead of 70 ah). Fitted a new battery with the highest ah and cca value I could find and the starter really kicks-ass now!!
thanks Mark, will try and check out battery levels. appreciate the help
My Octavia is 11 years old 102,000 miles and the original starter is still fine. I am on my second battery though which may suggest a solution for you.
