Cornering Fogs? Any benefit?
For cornering fogs you need a 23byte Central Electrics control module. Generally found on 57 plate cars onwards (although some late 07 plates have the controller).
Using fog lights as a cornering light is not illegal due and looking at cars which have it as standard I can't see any difference in the lenses on them to mine. They only work under about 20mph and if you pick adaptive this is IMHO better. This means say for example you are going around a roundabout your right hand light will be on. However if you indicate left it cancels the one on the right and illuminates the left light.
I find it really useful especially on some of the dark narrow unlit roads near where I work. Has stopped me hitting a few potholes that otherwise I probably would have missed.
Each to their own I suppose. :)
Good memory! :giggle:
  • Replies 74
  • Views 9.7k
  • So is mine, so you can do it.   Carista App used to add: activate DRL [no need to on Vrs];  tear wipe on front and rear wipers after wash; rear wiper activates if in reverse and front wiper
  • My earlier replies were to Adam with his 2012 model. DRLs, cornering lights etc were included in face lift models. However, the Carista information shows that cornering lights are possible on pre face
I did say that to you yesterday after checking yours :p :p
Your just jealous that i have it and you don't :rofl:
:moon:
:moon:
:moon:
:moon:
hi guys, i can find the box to tick to activatre the lights to work, but where do I activate the MFD in the vag to be able to switch them on or off from the MFD??
Kris
Edited by kris Hill
I think it would do it automatically. Probably depends on what model year it is. I have a MY08 corner lights enabled but no option of turning it on and off via the maxidot.
Kris
As I understand it, you can't. The only maxidot option relating to 'cornering' lights is for the adaptive OEM xenon headlights.
I have a 2010 FL vRS 170
I did not order xenon lights.
I asked my dealer about this option and they said only available on Superb and Octy with xenons.
So you say I can enable it then?
thanks
Dealer is a tit.
Cornering fogs to them are the mechanical units in the Superb and Octy with Xenons
All you want is the care coded to enable them. Sure you dont have the mechanical ones but this does not mean you cant code them to have a very simliar function. My dealer said they would do it, then when it was delivered to me they said they could not - was peeved as i said i could provide them the coding if needed.
Idiots - Watford BTW
Anyway - got a third party to enable it for me.
  • 8 years later...
Would any one be able to help, I’m in Oxfordshire  and if any one who has vagcom or vcds . Can they activate fog lamp ?
There is a list and a map of people willing to help with VCDS by going to the home page and then following the sections below:-
Hi I have brought a Carista how can this be done on the app?
Plug your diagnostics unit into the diagnostic port (on the right side, almost hidden, on the underside of the dashboard trim near the bonnet handle) and connect to the app with wifi or Bluetooth as appropriate for the diagnostic unit you bought.
Tell the app the make and model of car etc and open the changes page and make your choices.
Cornering lights are available on face-lift models but may not be there for earlier cars.
What age is your car?
It’s a 2012 model.
11 minutes ago, Adam26 said:
It’s a 2012 model.
Carista App used to add: activate DRL [no need to on Vrs];  tear wipe on front and rear wipers after wash; rear wiper activates if in reverse and front wiper is switched on manually or automatically; cornering lights using front fogs; lane change indicators changed to 5 secs on time; coming home lights enabled on dip beam.
Brilliant , I know what I’ll be doing later. Can I add digital mph with Carista?
Unfortunately no. Once you are connected through the diagnostic port, you will see the full range of options.
I have got a Carista for my 2007 model which will arrive in a couple of days. Will let you know if I can do cornering fog lights on that one also.
Are there any other good/useful functions that we can active? A sort of "must"?
The features are a bit Marmite. I love cornering lights (especially the fact that both fogs are switched on when reversing) as I live in a dark  place with no street lights) but others think cornering lights are pointless. Same with the tear drop wipe and auto rear wiper. You just have to try them and make up your own mind. Let us know what you end up with.
From the Carista page after putting in your model year, the features list is shown below, however from what others have said I believe some features may not work on pre-facelift. :
EDIT. The list does not show up on some browsers. You may have to swipe to see.
So here is the alternative:
https://caristaapp.com/vehicles/skoda/octavia/mk2
Doors / Windows / Remote
Auto-lock doors when moving
Yes / No
Auto-unlock doors when key is taken out of ignition
Yes / No
Pop trunk via remote
Enabled / Disabled
Beep when locking with remote
Yes / No
Beep when unlocking with remote
Yes / No
Blink turn signals when locking with remote
Yes / No
Blink turn signals when unlocking with remote
Yes / No
Beep when locking with key
Yes / No
Beep when unlocking with key
Yes / No
Close windows via long-press on remote
Yes / No
Yes / No
Blink turn signals when locking with key
Yes / No
Blink turn signals when unlocking with key
Yes / No
Unlock doors via remote
Driver's door on 1st press, all on 2nd / All doors on 1st press
Enable settings for opening/closing windows and sunroof
Yes / No
Open/close windows and sunroof via long-press on remote
Yes / No
Open windows via long-press on remote
Open sunroof via long-press on remote
Yes / No
Close sunroof via long-press on remote
Yes / No
Open/close windows and sunroof by turning and holding key in driver-side door lock
Yes / No
Open/close windows and sunroof by turning and holding key in passenger-side door lock
Yes / No
Open/close windows and sunroof by turning and holding key in trunk lock
Yes / No
Open windows by turning and holding key in door lock
Yes / No
Close windows by turning and holding key in door lock
Yes / No
Open sunroof by turning and holding key in door lock
Yes / No
Close sunroof by turning and holding key in door lock
Yes / No
Sunroof action when opening via remote
Slide / Tilt
Alarm system
Enabled / Disabled
Alarm system disarming
Via remote or key / Via remote only
Re-lock doors automatically if you unlock, but don't open a door
Yes / No
Enable remote control buttons when ignition is on
Yes / No
Delay alarm activation
Yes / No
Instruments / Display / Dings
Instrument cluster language
Chinese / Czech / English / French / German / Italian / Portuguese / Spanish / Symbols (no text)
Instrument cluster region (affects ext. lights too)
Germany / Europe / USA / Canada / Great Britain / Japan / Saudi Arabia / Australia
Seat belt warning
Enabled / Disabled
Lane-change turn signal auto-flasher
Enabled / Disabled
Lights
Daytime running lights
Off / All lights / Headlights only
Use fog lights as daytime running lights
Yes / No
Side marker brightness
0 - 100 %
Daytime running lights (DRL) brightness
0 - 100 %
Front parking light brightness
0 - 100 %
Rear parking light brightness
0 - 100 %
Rear brake lights as parking light brightness
0 - 100 %
Rear fogs as parking light brightness
0 - 100 %
Disable US side marker lights (US models only)
Yes / No
Coming-home lights
Enabled / Disabled
Leaving-home lights
Enabled / Disabled
Coming-home lights mode
Based on personalization / Automatic
Ambient light threshold for leaving-home lights
0 / 1 / 2 / 3 / 4 / 5 / 6 / 7
Additional high beam with bi-xenon
Yes / No
Turn off front fog lights when high beams are on
Yes / No
Rear fog lights
Enabled / Disabled
Cornering lights
Enabled / Disabled
Cornering lights use…
Disabled / Fog lights / High beams / Xenon lights
Flash brake lights in emergency stopping
Yes / No
Other
TSC (Torque Steering Compensation)
Enabled / Disabled
Lower passenger-side mirror when in reverse gear (req. memory seats)
Yes / No
Additional 'tear' wipe after windshield washer use
Yes / No
Additional 'tear' wipe after rear window washer use
Yes / No
Auto-enable rear wiper when front wipers on (interval) and reverse gear engaged
Yes / No
Auto-enable rear wiper when front wipers on (continuous) and reverse gear engaged
Yes / No
Edited by pikpilot
Added direct link
Thanks Pinkpilot! That is quite useful
As a feedback, in my 2007 prefacelift I cannot program the fog lights to act as cornering lights with Carista. Just tried.
My earlier replies were to Adam with his 2012 model. DRLs, cornering lights etc were included in face lift models. However, the Carista information shows that cornering lights are possible on pre face lift model cars as shown in the link. It also says fogs can be used as drls.
I suspect the sample information for pre facelift cars may be wrong, in which you case you should be able to get your money back.
In case anyone looks at this thread with a later car fitted with drls, it is a two step process. First you have to activate the drls with Carista, VCDC or other software and then switch on the drls  using the left hand stalk as shown in the handbook. These steps only need to be done once.
right I've brought the barista and wating and will update when I find out.
the car has maxi dot (dog and Columbus nav)
Hi all. Quick update.
carista arrived and for £15
its enabled digital speedo as I have maxi dot.
enabled fog lamps when turning left and right and few more worth the £15 and does a few other tricks worth it in my own opinion.
I have done coding described in this forum to activate cornering lights on Octavia MY16, and it worked.
But cornering light work only when lowbeam is on, not when DRL is on (DRL bulb is located in inner part of headlight).
Does CL works along with DRL?
If so, can it be activated?
That's the correct behaviour...
You don't need cornering lights during daylight hours ;)
Thanks for such a prompt reply :)
Seems I have another logic, so I was trying to "hack" software to make them run with DRLs.
If there is someone with same logic and more skills in VCDS than me, let me know :)
