Alloy wheels
16% error like that should be an MOT fail. Maybe like mine it had the wrong tyres to begin with? (should have been 165/70R13) Technically 205/30R17 should be the correct profile - if the speedo isn't dodgy then the 40 profile should make it under-read which again is a definite MOT fail, so I would definitely check it like you said and hope any errors cancel each other out!
No it's not. The speedo is not and has never has been a part of the MOT test.
Random question but do you do photography by chance? Damn sure I used to see that car when we did longcross etc when we played at rally years back.
Look at the rear doors a bit more closely! :p
Ah now I see. Browsing on iPhone so didn't see the graphics. :)
Just fouls on the track control arm but only on full lock mm off lock n its fine
Yes - you have a good memory as its 7 years now since I owned that car - still doing the photography though :thumbup:
What car did you used to rally?
My bad, I'd always been told it was. I guess it's only a potential issue if you get pulled over then.
We had a mk2 SEAT Ibiza Cupra.
Edited by Tech1e
NICE, i prefer mine tho HAHA
before rolling roads for brake tests then cars were road tested and the speedo was part of the MOT but they are no longer tested as there is no road testing involved
Dave
Edit* erm also i tested the speedo against a digital speed camera thing near my house, tells you how fast your doing, at 30 on speedo im doing 29 :)
Edited by felicia1.3lxi
that seat is absolutely beautiful.
agreed, if they weren't so damned expensive i'd buy one tomorrow :thumbup:
  • 2 years later...
As promised, couple of pics of my old Felicia - wasn't very standard as you can see! B)
Google images powered thread revival :D
Anyone know what arches these are? They don't look as large as the kit car ones. I like them. Even more of a longshot that they'd still be available, but you never know :p
I after some too... still looking been busy on my felicia my alloys are in need off repair or I would put pick up running 16s 7.5j
Hi ive just fitted a set of 17" azev A's 7.5j onto my skoda pickup.... tgey came from a vw corrado... tge offest is slightly different to the origonal 15inch skoda wheels but they fit spot on with no rubbing issues... the hieght of the truck rose by approx 15mm but a set of springs shoukd sort that out... as for handling it has 64bhp... u dont by a pickup if ya want handling... its a pickup lol.... as a note on handling... u can get the strut brace from the petrol car version and it fits straight on that should tighten the front end up a bit....
