Rear Washer not working on Roomster 1.9 tdi 07 plate
Hi,
A few weeks ago I noticed that when trying to use the rear washer on my Wifes Roomster you can here the pump spinning but no water comes out. The front washers work fine? This was before the deep freeze set in.
Any ideas what it could be or where I should check if simple (I am not very mechanicaly minded) other wise I think it will be a trip to the garage.
James
Might just be clogged - get a needle and gently push it into the nozzle hole (not too far mind).
If there's a blockage, that should clear it.
As ap0gee has said, and I totally agree.
It is a common trait with Skoda models, one frosty cold spell and the washer pipe connections pop-apart, particularly the rear one.emoticon-0105-wink.gif
Thanks. I will get the garage to have a look.
Best wishes
James
I had a very similar sounding problem to yours. Took it to a dealer who told me that a pipe had burst so I wouldn't be surprised if this is what has happened to yours. It's nice to have a clean rear screen again!
Thanks for the warning I think I'll have a look at my tubing to see if it's feasible to add some insulation. I'm not experiencing any problems at the moment, but there again it hasn't been as cold as last winter yet.
