Idling and running issues on vRS 2002
Im having some idle issues and running issues on my octavia vrs,
when i start the car it runs high revs ( auto choke) for approx. 10seconds then jumps from 1000rpm to 400rpm and then eventually dies, after holding the accelerator for approx. 30sec at 1500rpm it evens out and good to go, but then when car is nearly fully warmed up 10miles driving, i go to put my foot down and the revs will stop at 3800 - 4000rpm stutter for a bit backfire/bang/pop from the exhaust the fly off like a bitch,
i dont understand why it is doing this,
im running a k03s hybrid,
straight threw stainless steel system,
de-cat,
fully enclosed ram air k&n system,
forge splitr dump valve,
and a few other little things
any ideas or views welcome,
thanks,
MAF sensor could be gunked up. Worth cleaning the throttle body too. Check to see if you have the old type black Coolant Temp sensor as it's notorious for failing & can cause erratic idle.
Edited by pauldazzle
also check for split breather pipes
Excellent, thankyou, ill have a check of these tonight,
where abouts is the coolant temp sensor located?
cheers
Follow the top hose of the rad, & the CTS under the lower engine cover, which you'll need to remove.
You really need to get a Vagcom diagnostic done before you start throwing parts at the problem, but if you have a black CTS I advise you change that for the later green CT regardless.
also what would the new temp sensor look like? if i get one from skoda will it be the new 'type'?
excellent cheers,
was the prob with mine got my new one from car spares 4 pounds 9 pence all in
Genuine VAG part :thumbup: I bought a cheap aftermarket CTS for my old A3 Quattro, & it lasted a whole 3 days before the temp gauge started going crazy, & the ECU started over fueling thinking the engine was cold :thumbdown:
