DPF removal and re-map
Can the DPF be put back on if needed and is it classed as a mod so do you need to inform your Insurance company even if you have a re-map that doesn't increase BHP (Stops at 170)
Different people will change it in a different way.
For example, when I spoke to Ben at Shark they take the filter out but leave the casing. Others will remove the DPF entirely and replace with a straight thru pipe.
Silly as it is you could "theoretically" put a 7 litre V8 in a prius & still pay the same tax although the car made of bacofoil would probably collapse under the weight. The thought of a Prius with side pipes spitting flame does seem strangely appealing though
Thats different that would be classed as a Engien transplant you would have to change it on the log book so it was registered as a 7.0 V8 and then you would be taxed accordingly
But yes you are right without the DPF the car still pays the same tax
Bugger, if you are right thats another project shelved
How do they asses it as the emissions can only be established by testing the car as exhaust etc all have a bearing. It cant be established by just stating an engine size. Many people swap engines in cars but I dont know of anyone who has had to go for an emmisions test, I believe its only required for cars being registered as specials & needing the dreaded Q plate
Edited by Stuart_J
Hahaha
Veyron powered Prius
Ive had the usual 2.0 PD Engine stutter problem that i solved with a Skoda Gasket, Ive recently discovered that my Milltek DPF Delete pipe is also leaking so taking it back to Milltek HQ on the 17th
Not been on the forum for a while. What's the 'Skoda Gasket' cure for stuttering all about?
Its not actually a Skoda gasket but Skoda UK where first people to try it on Fabia PD130's so i call it a Skoda Gasket, Its actually of a MK3 Ibiza
Basically theres a Gasket on your EGR Valve, You fit the new gasket in its place, The new gasket has got a smaller hole in it so lets through less "cr4p"
Here's the orignal link: Link Thats for PD130 Engine tho
Heres my Guide for PD170 Here
Edited by AndrewJB
Thanks Andrew. Unfortunately the PD170 link appears to be broken...
Try now i had put http:// twice :giggle:
Whats this Climatronic "Off" MOD?
Edited by AndrewJB
No good for me Leon doesnt have the same "Knobs" as The rest ive got buttons
Heres a repost of my thread
As most of you know ive had a stuttering problem for ages (Well since DPF Removal), It does it mainly when launching from a roundabout or traffic lights in 1st and 2nd gear and then when on motorways when accelerating in 5th and 6th.
Ive read about a fix for PD130,PD140,PD150 & PD160 Engines so ive tried it out on the PD170 and it seems to have fixed it :D :D :D Been for a 40 minute drive since and not been able to replicate the stuttering
So whats needed:
1x Part Number:028131547B (£2 From Dave @ SERE Motors)
1x T50 Torx Bit
Below is the original Gasket (Top) and New Gasket (Bottom)
And this is where the old one came from and the new one is going
Basically all as you do is remove your engine cover and undo the two T50 Bolts off the metal pipe! Pull the pipe away from the EGR, Mine was stuck so i used a biggish screwdriver to do it,My old gasket was also stuck on so i also used a smaller screwdriver to pull that off the pipe and remove it.
Slide the new gasket in and fasten it all back up
Takes literally 5 minutes :D
As i said it seems to have solved mine! Not been able to replicate it but im not promising it will fix everybody's but for £2 its worth a try
Edited by AndrewJB
Many thanks. Does this 'cure' help with cars still fitted with their DPF? Or does it just cuase more problems? And out of interest, what happens to the 'crap' that can no longer go through the hole?
Edited by rsbspt
Fitted one to my DPF equipped cr RS and I had no issues since fitted. The car seems to have I bit more pulling power between 1200 - 1800rpm in second where before it was fairly dead. :)
Edited by jcdub
I carnt really comment on what effects it will have with a DPF still fitted
The principle behind this mod is the EGR is there to open and close when needed,it opens and lets "Sooty fumes" back into the engine for a 2nd pass to burn more stuff off, The Smaller hole means less of the sooty fumes end up going back throught the engine so the engine gets cleaner air and therefore runs better
The Stuff that doesnt go back through the EGR just goes out of the exhaust :thumbup:
Thanks Andrew. I take it that's a SEAT part No. you've quoted? It doesn't look lke a Skoda one...
Yeh its a MK3 Ibiza Gasket
Dave @ SERE Motors in ireland does them for £2 delivered his details are on SCN
