power steering light come on and steering becomes manual
hi, i got a skoda fabia 1.9tdi 2004
sometimes in the morning the power steering light comes on and i have no power steering
i read other peoples problems about lights flickering and electric problems. i have no other symptoms just power steering stop working
would it be the steering angle sensor or could it be other things?
i look forward to your reply, martyn
Could be the steering angle sensor, or battery. The PAS takes a lot of electrical current and if your battery cannot deliver that then the system is disabled. If the PAS only does this after starting first thing I would suspect the battery rather than the angle sensor especially if your battery is original (ie. 6 years old)
Hi mate, welcome to the forum!
I have a PAS problem on my Fabia Classic 1.4MPi which comes and goes.
People sugest it is either your battery or the PAS sensor that is to blame. However just this morning a mechanc poped round and said that mostly likely my alternator is giving up.
Let us know how you get on
Edit: Check battery first winter finishes them off if they are old
Edited by Vinjy
thanks for your reply, i have seen no sign of it being the battery as it starts fine every morning and nothing dims down
martyn
Mine starts every morning too even in -7 temps and everythnig works fine-ish... except the steering.
Get a mechanic to check your alternator
yeah , i know how to check the alternator myself
ill do that if itsw okay ill get a battery this week
thanks again, ill be in touch
Wish I knew how... :D
i'm a qualified mechanic
to check the alternator when the engine running put a volt meter across the battery and should be between 13.44 and 14.44 volts
to check battery you put volt meter across termals when switched of should be between 12.5 and 13.00 volts
ive checked both and there fine soo thinking could be the sensor
grrrrr
In my case on the 2004vRS the dealer suggested it was the PAS sensor but he ended up changing the rack!
My VRS done this on the first frosty morning of this winter and it was the battery in the end up mate
The car even started ok fist time with it but when i switched the car off to try and clear the fault it wouldn't start again hence knowing it was the battery.
Daz
The power steering light in my fabia used to come on and steering sometimes lost the power assistance.. I fixed it by changing the sensor. I suspected the sensor was at fault though because I could be sitting at traffic lights and I would hear the PAS pump working and the lights would flicker.
