Fabia power steering problems?
  • Sponsor
Does your car have the Koyo, or TRW steering system?
  • Replies 254
  • Views 332.1k
  • Here's what VW say about it: http://www.volkspage.net/technik/ssp/ssp/SSP_259.pdf Whether the system uses G250 sensor or G85 seems to depend on absence/presence of options like ESP.
  • For the more technically minded. the Chassis workshop manual, this includes all the coding and value block data for the power steering control unit. Fabia Chassis.pdf
  • Breezy_Pete
    Breezy_Pete
    The parts catalogue suggests oils meeting VW group spec G 004 000, for both Koyo and TRW steering systems. oil container and connection parts, hoses; ; no '... - Fabia(FAB) [EUROPA 2000 year] (7z
i dont know, how do i know that?
  • ColinD unpinned this topic
  • 1 year later...
I had the dreaded PS warning light in June, topped up fluid and replaced the fuse on the battery (red/black wire). Since then I have fitted a 80Ah battery (was 52 Ah) and tested alternator. All was well until recently when temps dropped,  rain rolled in and so did the PS warning light.
The vehicle is a 2001, 1.9 TDi Fabia ATD and I want to gain a better understanding of why the TRW electro-hydraulic pumps fail. TRW and others sell new with a core exchange and my aim is to strip, test and replace anything serviceable that has failed and save a bucket of money (if possible). At this point I don't have a scan tool and will look into buying VCDS in the near future.
Any thoughts as to why the fuse blew? The PS fluid level was down a centimetre back in June but I can't speak historically. I binned the foam pump cover as it was loaded full of oil/water and I understand the reservoir can leak from the  O-ring. Can PS fluid/water enter down into the electrical plugs and damage components on the PCB? People have commented about holes in the base of the female plugs on the pump body.
Also I have read about transistor failure on the pump control PCB. Below is a link testing supply voltages and transistor replacement. Is is possible the steering angle sensor can somehow overloaded the pump transistor leading to its failure? For anyone interested the transistor is IRL3705N. I will also look at the capacitors as car is at 230,000 km.
An old topic now but any feedback would be appreciated.
  • Sponsor
VCDS Lite (freeware) is adequate for mk1 Fabia, you just need to buy a suitable KKL cable, very cheap compared with full VCDS.
Did it blow (visibly melt?) or just crack? The cracking is I think a purely mechanical issue, nothing to do with the pump or current flow.
Yes, I think if the sealing round the individual wires, or any connector's mating parts fails, water has holes it can go through.  Not sure if I have a photo of this, but have an old pump unit at work I could look at on Monday.
Thank you Brezzy_Pete and nice to now there is free diagnostic software available.
The fuse definitely looked to have cracked with no signs of thermal damage, good point on mechanical failure.  These PD engines do rattle a bit.
Re the plug if you have time it would be appreciated.
