Temperature
My car keeps randomly saying the temp is 20c and stuff like that... Is this a common problem? Is it just a case of replacing the sensor?
Anyone got a part number?
Edited by vRS Turbo
water temp on the gauge or outside temp reading?
soz outside
more than likely the sensor but i havent any info on the location or part numbers sorry
I think it's in the bumper on the right hand side. At least there was an extra plug that side when I had it off, so I assume it's the outside temperature sensor. No idea on the part number though.
Wot you on about?... this is the UK... its always 20c here emoticon-0140-rofl.gif
Yes.. if you pull the lower-nearside (or on the right if you look at the car head on) grille off, the sensor is on a bracket there.. you should be able to see if theres any damage to the wiring too.
I believe its on the N/S
By the screen washer bottle (the wireing)
Edited by stevobeavo
