LED handles now on the vRS
Fitted some gloss black handles to the car today and the front ones now have small LEDs in them that light up when unlocked.
So, handle with led fitted in the rear
Basically i drilled a hole and fed the wires through the handle and filled the hollow part with silicon to waterproof it more.
The exiting of the wire
Joined the LED wires to some more wire after feeding it through the door
Then wired them into the lower door open/puddle light connector
Handle mounted on the door
Finally a video to show what the idea and outcome is all about
Thanks for looking
Very interesting. Nice unique mod
Very good!! Nice to see something different.
Now that is unique!
Well Done
Karl :thumbup:
What happens when you wind the window down though? (I'm thinking wires here)
The wires have been put out of the way of the windows
Hmmm id love to do this have you just tapped into the red puddle light?
yep
do they come on if you turn the interior light on constant?
They are wired to the door lights, so no ;)
very nice touch buddy
When i saw the title i thought oh no but tbh they don't look too bad.
nice work though!
Have to say that looks pretty good :thumbup:
Good job!! I did think about this but it was sooo much effort.. :giggle: I suppose if you were changing the handles anyway it doesn't seem too bad..
The version I was thinking of was drilling hole near the base, thus shining it parallel with the side of car.
I had a good think about where the leds where going and decided on the middle as they shine exactly in/on the handle recess.
This looks great! Is there no way of making them a bit less bright though? I dull amber or green would look aswesomly oem.
how did you get the beep when locking? :thumbup:
jordan
jordan
Find someone local with VCDS and you could have a 'Beep' tooemoticon-0148-yes.gif
I like the crisp brightness but having a mess with the LEDS i have noticed that if you file the top dome part down flat, the light throws less and seems to be more diffused.They also look a little less bright.
I like this mod :thumbup:
Going to get a price to have my handles colour coded, may well look at fitting an led too seeing as they will be off the car anyway.
