Engine Warning Light
The engine warning light keeps coming up on my 2003 1.2 fabia. It stays on for a couple of days at a time and then goes off for a while but always come back on. Does anyone have an idea which may be causing this to happen.
Cheeeers
John
It could be anything, you will need to get it scanned when the light is on to see whats wrong with it
Yep a code scan will reveal all. The light means it has recorded a fault.
And even if the light is now out, the logged fault should still be stored in memory.
Where abouts are you, maybe someone can help with vagcom... Sorry if it says at side, I'm on phone and it doesn't show me :(
It says Aberdeen at the side!
