air filter
what'sthe best air filter to use in the standard box on a vrs and how does one modify the std airbox
cheers
the original OEM one - all the others don't filter as well and won't give you more power - so why bother?
Original paper here
Pipercross here. Noticed a tiny improvement over the paper filter.
Also get more noise from the re-circ valve :)
Standard VAG filter and change it regularly... they're cheap enough.
OK, it's time to change my air filter, I don't want to pay a fortune, I don't want a fancy one, just want a OEM or equivalent.
Called Skoda, they want £12.75 + VAT.
Had a look on eBay and I'm seeing the likes of this for about a thrid of the cost.
What's peoples thoughts?
Tom
k&n and cleaned regularly - not sure on a power gain but it makes a nice woosh on boost :giggle:
if you want the original vag item at a very cheap price call Sere Motors in N Ireland and ask for David Hawthorne in parts
  • 4 weeks later...
How regularly should you clean em?
It says once every 50'000 miles but i do it every service and check it between services.
Cheers for that, I use to have one in my passat but only had it in there for like 10000 miles before I changed it out for an induction kit I got well cheap off ebay. But frankly It wasn't a turbo so not sure what I was thinking at the time :rofl:
If you clean them regularly, they seem to be the most cost effective option to me, and everyone likes a slight woosh!
cheers
Here is my DIY guide if it helps as you were asking about modding the airbox..
http://briskoda.net/forums/topic/181301-airbox-mod-and-3-pipping/
Don't have to drill holes before people start on the old "Heat soak" thread again.. :rofl:
