Better Boot Lighting
Apologies if this has been mentioned before but for €35 you could have just fitted these Octavia specific LED replacement lights:
http://www.superskoda.com/Skoda/OCTAVIA-II/Octavia-II-MEGA-powered-LED-dome-light-for-your-trunk
See this thread on the Yeti forum:
http://briskoda.net/forums/topic/179992-upgrading-the-yeti-boot-light/
The Yeti has only one (pathetic) boot light and just changing the one made a HUGE difference! :thumbup:
  • Replies 53
  • Views 7.1k
On the dome light feed - did you just splice a wire in then shrinkwrap/solder up again?
Not quite so simple unfortunately :(
Basically there is a constant live feed to the dome light, and the earth is switched by either the doors or a permanent earth, hence the sliding switch. You need to identify the earth circuit on the dome light circuit board, AFTER the switch, then connect to that.
I must confess I was too lazy to get the soldering iron out, and simply wrapped the wire around a suitably exposed part, then covered with insulation tape to avoid any shorting!
These are the S\skoda ones:
Footwell lighting-sorry, camera is not the best for night photos......
And yes, the car is being hoovered etc., this afternoon :D
Good stuff, cheers.
Thanks for the photos too.
Enjoy your hoovering :D
Think its nearly time to meet up and see all these subtle mods :)
Looks great in fairness
