Full TOOL Kit !
I'm looking to invest in my own Tool Kit which can help me do the smallest to the biggest repair (or any other ) job on my octavia !
Any suggestions ....or I'm being hysterical and there isnt any such tool kit available ??
I have no idea in this matter whatsoever please HELP !
Of course it exists. Just depends on how much you want to pay...
If you wont to pay lots of cash Snapon and Mac are the best,but for a starter kit you wil get good value from
Tengtools Very good value ,you can get start up kits and add as you go along I found this on Stealbay
http://cgi.ebay.co.uk/TENG-TC8140NF-140-PIECE-SERVICE-KIT-/230589811352?pt=UK_Hand_Tools_Equipment&hash=item35b0394a98
But i would look at what type of work you will be doing and buy any specialist tools as you need them .
Edited by patrol man
Im looking for a kit that can be carried around .......... and also help me with most of the work ..!
For example -like changing stalks, or a windshield bottle etc etc....
basically i want a tool kit resembling a octavia vrs estate ...... practical when i want to and fast when i dont want practical ! :thumbup::thumbup:
maybe I'm not that good at giving examples !:p
Edited by pz1811
I have just shopped around for tools which I have bought largely piecemeal there are good deals out there if you are prepared to compromise.
Buying an all in one kit generally entails an unformed compromise anyway, some of the higher end stuff like Snap-on may be better on that though.
Whichever way you go Murphy's law will still mean that the tool you actually need is not in your box !
I really like the Halfords professional range. Same quality as Snap On & MAC and also same lifetime warranty. You break it during intended use and they change it.
I have this set (along with a fair few other bits) that i bought about 4 years ago
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_173083_langId_-1_categoryId_165572
The 1/2" Drive broke recently and i took mine in to my local store and they swapped it for a new one there and then no hassle.
http://www.halfords....tegoryId_165572
i like
:thumbup:
Machine Mart Clarke Pro range are very good with a lifetime warranty and very good prices.
Cheaper than Halfords and a better range.
Given that the OP has 'India' as his location he's unlikely to have a Machine Mart or Halfords locally.
Best bet is to get some mid-range general socket and spanner set (which should include 16mm and 18mm) and some screwdrivers and a Torx set.
Anything else should be bought as the need arises.
Buying Snap-On would be a complete waste of money for a non-professional.
Edited by Hauptmann
I wouldn't buy a massive cheap toolset, buy just a few decent quality items. Tools i use:
17mm socket for the wheel bolts
13mm socket, everything needs a 13mm socket on VAG :giggle:
Torx bits, variety, engine undertray is T27 from memory? Might be wrong, but there's enough different sized Torx fasteners on VAG cars that i'd buy a small torx set T-6 to T30 only the not every size between them, only the 6 popular sizes, im sure something suitable will jump out if you search, a rail of 6 assorted torx bits with a 3/4 or 1/2 drive. Buy something decent quality to avoid stripping the fasteners though.
General purpose screwdriver set, flat head and cross heads
Hex socket for the brake calipers, can't remember the size though but search should find it
10mm socket for the battery posts and a few others
socket extension bar... actually that's a few sockets on the list now, maybe cheaper with a metric 3/4" or 1/2" set that comes with ratchet & extensions
19mm socket for the oil sump plug (cheaper than a 19mm spanner)
Caliper windback tool, clockwise for VAG rear calipers
Wire brush
Sundries:
WD40
Brake cleaner
Copper grease, small tube dont need a big pot
White lithium grease (for hinges, locks, gear linkages and what not)
Can;t think right now but those are all usable all the time on VAG cars.
