Leaking water into drivers side rear footwell
We have had since new a 56 plate 1.2 Skoda Fabia. It's a secon car and not used much.
We noticed a strange smell for the last couple of months.
Today we found that the footwell in the rear mdrivers side of the car is soaking wet!!!
Can anyone advise on the problem and solution??
Pee Cee
Hi and welcome aboard.
I had a similar problem in my Fabia VRS, I believe it was due to the drain holes in the bottom of the rear offside door not draining.
The garage were aware that this was an issue with the Fabia and modified them under warranty.
Dave
PS. I had the carpets replaced under warranty as well.
Edited by DaveLees
There is a thread in the Fabia 1 section which details how to fix the problem, quite a simple fix but a common problem on the Fabia.
Davy
Pee
Edited by rickytractors
Davy
Thanks for the reply? Can you send a link to this section ? Im afraid these webisites and forums are new to me
Papafox!!
Like afew things pal its been covered afew times on here. Most of us fabia MK1 owners have had this problem, I still do as ive been to lazy to do aything about it but after reading through this thread and seeing its pretty easy (follow the video on Page 18.) I am gonna do it this wk end
Here it is mate http://briskoda.net/forums/topic/2158-warning-fabia-door-leaks/page__st__340
welcome to briskoda
