hi am new
collecting car on fri, one problem the guy said is that alternator side one of the pulley squeals when its wet? but he is not sure wat pulley it is ? has any one replaced one before ?or had this prob before?
thanks dan
Edited by iomfabia
No idea my good man. Nevertheless, welcome to Briskoda :hi:
thanks dan
Welcome to Briskoda Dan!
Bart.
Hi dan, I had one replaced on my golf pd150. It's a fairly easy job and quite a common fault. As the bearings get older they start to seize inside the pulley. I believe you have to change the timing belt as well as it joins the alternator pulley to the water pump and you don't really want that going! Wouldn't advice a long trip with this problem! Hope this helps.
Welcome to Briskoda
Hi and welcome aboard.
Welcome to Briskoda
Thanks for reply . it had a cambelt 10k ago. i dont understand which pulley it actually is your saying is at fault?
thanks dan
