EGR Delete
Any dangers of carnage when doing it?
Do i need to do anything else to the engine when fitting one?
Is it an MOT fail too?
Dont understand the mod thats all.......bit green round diesel engines emoticon-0111-blush.gif lol.
  • Replies 63
  • Views 5k
Went to do it myself but opted out knowing that it could fail an m.o.t next year or year later.
Bugger it. They're there for a reason so just leave it there and just clean it out.
Cheers mate.
Any other views?
Mine's due for MOT Tuesday so I'm going to ask about this possible change. There is no way mine can ever be put back to standard in terms of EGR - There's no EGR point on my tubular manifold... funnily enough! :giggle:
Do i need to run a catch tank of some sorts if i do install an egr delete?
Cheers mate
I had done but everytime i search for something it throws all sorts of none related subjects up haha.
My link
What is the brass outlet hose connector for that screws into the flange?
Also what is the diamond shaped plate/gasket for?
Daz
brass outlet is if you want to run a boost gauge so you have the option
diamond plate and gasket gets mounted onto turbo manifold
all pretty self explanatory when you see it
why people fit these i dont know...time and money wasted...
just disconnect and plug the rubber hose that activates it....when you go for mot reconnect it.
I think the mot fail thing is rumour and not much more I don't understand how it's a fail I doubt there going to look for it!
emmission regulations are changing.....will fail when it does.
The egr restricts flow and gets rid of the oem connectors
Good enough reason for me
Plus it looks nicer and makes attaching hose work easier/neater, etc... I'm all for it personally!
yes oem egr blocked off works, but the egr has a venturi effect on airflow
egr delete will offer better flow, but will it pass emissions in the future
only time will tell :thumbup:
Surely a really restrictive map will allow it to pass an MoT without an EGR?
Does any one know how much the egr delete changes emissions I don't think anyone can know for sure that it's going to fail as I doubt any one has done a before and after, emissions can be a factor of many things as well!
cant be much as mine has 270bhp with it in place...:wonder:
cant see it for engine cover..:p
moggy said not long ago in a thread emmission changes will make it fail if removed .
Im presuming that moggy is a fellow briskodian and not your cat? But your car won't produce the same amount of emissions all the time or will it?won't injectors fuel ect ect have a part to play, ie had a friend who failed on emissions then put some sort of injector cleaner in his tank then took it for a boot next thing he passed, I'm not saying your wrong as I have no mechanical experience, just seems odd that people are so sure it's defiantly going to fail?
Lol what ever.
I'm not arguin, but doubt you've actully seen inside of a egr valve.
Exactly why i was wanting to do i mate.......makes it alot easier connection wise for when i make the pipes for my front mount.........'the old one off your car' ;) lol.
So will it cause any long term affects to my engine?
I know alot of you have done it already but is there any risks involved?
Daz
Lol what ever.
pmsl...
a spindle about 5mm thick running thru the centre with a release plunger at the bottom is that about right?
so if it reduces flow and mine runs at peak 2.3 bar would it run higher with a delete pipe in situ?
