gearbox oil change
I'm going to be changing the gearbox oil on the vrs this weekend. Quick question...how much oil does it take?
Just under 5 Litres :thumbup:
gearbox oil is just under 2 litres of G060726A2 - buy two 1 litre bottles
make sure car is level then remove filler plug, then drain plug, retorque to 25Nm, fill box until it drips from the filler hole
you are then supposed to run engine for 2 mins, and recheck level
box should be filled level with the bottom of the filler hole.
p.s. a funnel and length of tubing make refilling much easier
gearbox oil is just under 2 litres ...
sorry I was thinking of my other gearbox ...
The O2J gearbox is 2.1 litres
Good guide
Yeah capacity is "1.9 + 0.1 litres".
You'll need a 17mm hex key socket for the plugs.
Cheers fellas.
