Lower On One Side Than The Other
My mates SE is lower on one side than the other. We have had the springs our and they are identical. They are sat the same. We don't know what it is. Anyone got any idea??
Lower side
Other side
Any help would be appreicated
just check that springs are not broken, maybe a weak spring or how its sat if on a dive etc
something aint right there, you sure hes put the adjuster cup in the other side, as i doubt it would go that low with the adjuster in place
Both adjusters are out. We have just had the springs out and they both seem fine.
is it sat on the wheel and wont go lower? my pasenged wheel sticks out 2mm more than my right. :rofl:
other than that.. softer spring?
Try swapping the springs round see if its spring related. Defiantly something wrong tho
No they are both just adjusters out drivable etc but he don't like how one side is lower as I wouldn't either lol
the higher one looks same as mine and i've got adjusters in.
Other one looks like adjusters out.
why is he driving it looking like that? surly not safe either :giggle:
Its normal
They never sit straight!
Ive had 2 on coils and they never sat straight
What coilover's are they?
but this is beyond 'not straight'. it's like 2" differance :wonder:
any chance of a clearer pic of the the nearside?
Will sort it tomorrow or Saturday
Fk
Any ("very heavy") subs/amp in the boot?
mines the same..
Mines the same!!! The spare wheel sits on the low side
mines the same..
and your OK with how they sit?
I'm on AP coils and I'm pretty sure it doesn't sit squint :o
All the vag cars I have had never sat level on the rear, don't know the reason for this. I would put the adjuster in on the low side and level it up?
I can believe a bit but that's nearly 2", that can't be right... Mine at like that
Is the problem at the front of the car, maybe a broken spring which is where the main weight is causing the whole car to dip on that side.
DB.
Mine aint like that either, i'm on AP's though.
Thats a huge difference !
Mine sits a tiny bit wonky, but nothing like that! Clearly something wrong
Matt
Are the coilovers new? Check to see if its a faulty shocker
