Possible misfire?
Hi all, i was driving today and the EML came on, and immediately it felt like a misfire. I checked using the handheld i keep in the car and sure enough misfire cylinder 3. Had all the coilpacks replaced last week so went to skoda who replaced coilpack 3. I was in a bit of a rush so i erased all the codes whilst the guy was replacing the coilpack. Started driving home and it happened again, cylinder 3. Got home and turned the car off took the key out and went in the house, came back to take it to the local garage and nothing, it ran fine and i gave it a bit of a beasting, which i think would have shown up a weakness.
Questions is, could i maybe have just not reset it properly and taking the key out has done it for me, or have i got an intermittent problem? What else could it be wiring? or something more sinister!
cheers
check the wiring on the coilpack, this can become brittle and fail.
mine feels like it missfires too, not all the time, usually for first few minutes after a cold start, but i get no warning lights on the dash when it does it, only started doing it after the coilpacks were changed last week. Although on mine, as with all the electrics on the car, I noticed some one has fixed/bodged the wiring for the coilpacks, looks like its been repaired at some point but not very well.
Either that or the plugs have had it. Whip them out and check the gaps. Should be 0.7mm iirc.
Just checked the wires and they look pretty knackered. Breaks on all of them. Guess it's a trip to skoda again for a new loom. Anyone know the code or price?
http://www.ecstuning.com/Search/Coil_Pack_Harness/ES7679/
An american site, but the part number should be the same. I think you're supposed to run the cables to the ecu and patch the new cables in there, but most people cut it and join onto the existing loom to save dragging it through all the trunking etc.
It still may not be the wiring. Check plugs and perhaps even swap coils before going further.
He said all the coilpacks have been replaced.
Worth checking plugs and gaps though.
Had this on my 4x4 4 or so weeks ago and was the coilpack loom.
I used
1J0 971 658 L (Harness)
8L9 121 659 (Heat Deflector)
Replaced it all the way back to the Ecu.
Looked like this at one point lol
Note on my 4x4 i had to join 1 wire to the new loom as it was not on the new 1 but easy to do.
All in cost was about £60 from TPS
Edited by JackDeath
