Upper Boost Pipe Replacement Guide
To start off i'm not a professional mechanic and this is simply a guide detailing the steps I took to replace the upper boost pipes and therefore I accept no responsability for any damage/problems that may arise as a result of following this guide, you do so at your own risk!
That out the way;
The tools you will need
Flat head screwdriver
T25 Torx
Hacksaw
10mm Spanner
Screwdriver was in my back pocket :D
The parts you will need
1 x Forge Bayonet Coupler 64mm-60mm
1 x Forge Bayonet Coupler 60mm
1 x vRS Dovit Stainless Boost Pipe (pm vRS Dovit)
1 x Samco 60mm - 51mm reducing 90 degree elbow
1 x Samco 60mm - 51mm reducing 45 degree elbow
2 x 50mm - 70mm Jubilee Clips
2 x 45mm - 60mm Jubilee Clips
Optional parts
2 x O-ring's
2 x Hose Clips
Guide
When I changed boost pipes I removed my front bumper, however I do not think this is necessary as removing the headlight gave plenty of access.
1)First step is to open the bonnet and locate the 3 torx screw and 1 bolt that holds the drivers side headlight in place.
2 torx screws
1 bolt
1 torx screw
There is also the wiring plug for the headlight which pops off at the back.
2) Next remove the hose clip at the EGR valve and then the clip at the Intercooler, pop both ends out and remove boost pipes.
3) Compare new pipes to originals and trim accordingly.
This photo shows roughly what I removed
4) Then insert the 90 degree bend into the EGR coupler (64mm one) and the 45 degree bend into the remaining coupler.
Put the Intercooler coupler in its place, adjust bend accordingly and attach clip.
Put the stainless boost pipe into the 90 degree bend, position the coupler at the EGR valve, it will sit closer to the firewall at this point insert the other end into 45 degree bend.
It is a tight fit, push the stainless hose into the silicone bends until the coupler is in line with the EGR valve, insert coupler and attach hose clip.
Check the pipes do not touch/rub against anything.
Tighten jubilee clips and replace headlight.
Finished
Estimated time: 1 - 1.5 hours
Estimated cost: £180
Dont forget Briskoda members recieve a 5% discout from Forge!
Hope this guide helps, any problems feel free to pm me :)
Good write up. Thanks :thumbup:
Amazing guide mate! got my samco hoses through post today! will order up the forge couplings right now :p thanks for the info buddy.
Awesome stuff Mike! - many thanks
Sorry to sound dense Mike, but in your parts list you mention a 60mm coupler, but on the forge link they have a 60mm/51mm coupler (type A) - is this the correct one?
is'nt the 45 degree pipe actually 135 degree's...
Looks good, sadly I sold my Dovit pipe to a needy Fabia owner :giggle:
Hopefully Davie will do another batch soon.
Unfortunately it was one of the parts I got off of TrevorB33 so didn't deal with Forge direct on this one, i'd imagine they could easily make a straight through 60mm one, if they couldn't you could just use a 51mm 45 degree bend instead of a reducing 60mm-51mm 45 degree bend.
Such as this
Ah wee bit of maths fun ...... its whats advertised so thats what I put
Nope thats known as a 45
Depends which way you look at it i suppose
Great work Mike
