List of After Sales Addon's
Depends where in South Wales you are ;)
Love the 'port
Love the 'port
You knows it bruv!
Once the big MPH is activated with VCDS can you switch the option on and off without the VCDS? Thought it best to clarify as wasn't sure if when gorebrush demonstrates in his video he still had the VCDS connected?
Yes you just enable it under the MFD
Thanks.
Can't decide whether I like the alarm beeps or not.
The unlock on remove keys is interesting but do the interior door handles not bypass the central locking anyway?
Yes, you can take the big MPH display and get the KMH back without any more VCDS tweaks.
And yes, if you open a door it'll unlock for you, and you don't have to open the door twice so to speak.
The number of times people have tried to rip my door handles off in order to get out of the car was unbelievable in the past.....
Yeh the unlock on key removal is kinda pointless on the MkII.
I also enabled to tear drop wipe on the wipers.
Argh, hate tear drop :D
I want to enable emergency stop hazards too...
"tear drop" ?
Does the hazards on emergency stop allow you vary the inertia / bracking force?
They had that feature on the Abarth 500 which I was considering some time back and owners on the Arbathisti forums were finding it way to sensitive and embarassing. :D
Tear drop - it wipes once more after a few seconds I think
Ah, thanks. My Clio used to do that.
Amazed at all these things being configurable options.
Well without VCDS they aren't generally.
Best £300 we've spent getting one!
Staging!
is it possible for all Fabia's and can dealers do it?
VRS does it from standard can't see why the others can't be set up to do it via vagcom IRCC
Gore, could you possibly post up a screen print of where you go to change the localisation in VCDS and a step by step guide as a friend might be able to lend me their copy so I can get the large MPH on the Maxi Dot?
Yes of course - I'll try and write up a guide over the weekend.
I'll show all the other options as well if people want?
Cheers mate, that would be fantastic :thumbup:
A quick search would of found the following that I posted for another member:
BEFORE YOU DO ANY CHANGES DO A FULL SCAN OF THE CAR AND SAVE THE SCAN, I CANNOT STRESS HOW IMPORTANT THIS STAGE IS!!
To set the country to Australia:
To change the country go to 17- Instruments and click on "Coding - 07"
Then click on "Long Coding Helper"
Finally under Bit 4 select "70 Country: Australia (AUS)"
Exit this screen and you will return to the previous screen (with the current & new coding displayed) you see that the long coding has changed, click on "Do it!" all will then be saved.
Once you have made the changes with VCDS you then need to go into the maxi-dot menu:
SETTINGS
Units,
"Consu/distance" change this back to mpg (GB), mi (as it defaults to 1/100km, km),
then
SETTINGS
"MFD data" and make sure the box for Digit.speed is ticked
You can also remove the KPH display and replace it with the outside temperature:
SETTINGS
and unticked the "ALT.speed dis." box (this will remove the KPH speed and replace it with the outside temp display)
For the staging go to:
17 - Instruments
Adaptation - 10
You will then find the 'staging' in the drop down box.
If whoever is doing the changes looks a bit worried about any of the above then I suggest you do not let them touch the car! VCDS is perfectly safe in the right hands, but someone who hasn't a clue can screw a lot of things up!.
You also need to make sure that the interface is a genuine Ross-Tech one as an eBay cable will not work on your car.
Saves me a job
I tried searching for the same myself before but never could. Stuff like this should be stickied.
Cheers Gizmo
I went to see my dealer yesterday to cross the t's and dot the i's and mentioned to him about the anti hijack function, not a problem he says, so pushing my luck I asked about setting the car for Australia, he told me he'll see what he could do, so fingers crossed the dealership may change this for me. Must admit the dealership is pretty helpful, they've let me also sort my own valeter and it'll only be him prepping it, so paintwork should be pretty tiptop from the start !
please delete this post
Edited by Wibb
