updating drivers? should it be enabled?
my system advisor says i need to update my driver? when i try to it says cant find a better match then the one i have? broadcom 440x10/100, it also says its disabled code 22? should it be enabled? means notin to me all that, any answers in layman terms please lol
Do you use a wired network connection into the PC? If not you can ignore it.
Code 22 is a 'device disabled' so sounds like you've already disabled the device either in Device Manager or Network Connections.
It's generally best to use the latest driver available for the devices you're using.
no mate i use wireless.so do i just ignor it then is that what ya sayin?
Yes, as it's not something you make use of. If you want to get rid of the message, just update the drivers anyway :)
its when i do try and update it, it says it cant find a better one. if its not gona cause a problem i mignt as well leae it then
Proberbly because you are trying to use windows to update the driver, to get the latest driver you usually need to visit the manufacturers website (in this case broadcomm) and manually download and install it. Windows will just attempt to get the driver from Microsoft which may not and usually does not have any new drivers.
http://www.broadcom.com/support/ethernet_nic/4401.php
Newest drivers are 2007, so its quiet an old adapter.
