Regarding vRS headlights and black headlights
Guys, quick question - do your chrome vRS headlights look like this?
My friend is trying to place the black ones but rather than 3 bulbs (+blinker) the black ones have only 2 bulbs (+blinker).
Where is the high beam? He and I are confused - can you enlighten us?
Mine look like that...
Maybe the black ones got another bulb?
Sent from my LG-P990 using Tapatalk
Edited by Confide
Yes thats the chrome variant. The black ones don't have the seperate High Beam I believe. Instead it used a bi-halogen projector - i.e. the same bulb does both high/dipped. It's purely because the black pack is nowhere near as reflective compared to chrome.
So if I understand well when placing the black headlights you leave the high beam socket unoccupied and connect the rest.
Do you get a fault for not having a bulb there and if yes is it a matter of vagcom to remove it?
Yes that's the chrome variant. The black ones don't have the separate High Beam I believe. Instead it used a bi-halogen projector - i.e. the same bulb does both high/dipped. It's purely because the black pack is nowhere near as reflective compared to chrome.
I'd imagine it will use a twin-element H4 bulb is used for Dip & high beam. If it is, the Dipped beam will turn off when maim beam is on. The standard twin bulb type, the dipped stays on all the time.
I notice there is a small side-light bulb, does it do anything as I thought the vRS uses the Fog/DRLs as side-lights?
The side light on the black lenses is completely useless. Its hard to see and just dims out the DRL's.
Dipped beams or nothing tbh
As far as I know the small side-light bulb does nothing on the chrome vRS headlights.
I believe the dipped/high is an H7
in regards to changing from 2 bulbs to1 bulb for dip/main I think the wiring set up may be different
Edited by barrheadred
