I'm loving my Vrs....
Car looks excellent, im planning on using my Das-6 Pro on Wednesday after I clay bar the car tomorrow.
Do you have any tips for achieving that good a finish?
Two words really, patience and perseverance!
It's hard work, so take your time and make sure you're applying enough pressure - you don't want the pad to be gliding over the surface at high speed :no:
Also, be sparing with the compound and keep an eye on your pads to make sure they don't clog up.
Don't go for the hardest cut from the off, try a softer compound first and go harder if you need to.
Don't rule out a second pass with the same pad and compound on an area if you're not totally happy after cleaning the residue off
If you get too tired to finish the job properly, or start to run out of time, dont rush it just to get finished. Better to do 75% properly and save the rest for another day - haven't done my roof yet
Don't know if that helps or not really?
Edited by sko-with-go
Being told about being carefully not to damage the paint work when machining it, is this done when you let the machine spin too fast on the body work?
Does so mate cheers
