induction kit yes or no or normal filter
i brought a green pannel air filter
when fitted the car doesnt go as well as when i put the standard air filter in
any ideas why this could be as thought the idea was to improve driving?
do induction kits work well on the vrs 1.8t or a waste of money?
was thinking of trying the k&n induction kit for £99
any body got one fitted and do these gain any performance or just noise
or should i stick to the standard air filter
any thoughts
Steer clear of ind kits where the filter fits straight onto the maf......there a no no!
Look for a decent CAI where the filter sits on the end of a pipe away from the maf and usually sits behind the bumper.
Or just a decent panel filter, I'm running a k&n in a modified box that has a 3" feed direct to the bumper, which IMO feels better than the CAI but nof as noisy.
Others swear by just buying new paper filter and just replacing it on a regular basis.
As SIVRS says, avoid open cone filters. They suck in hot air from the engine and sound chavvy. I tried one on my car for less than 24 hours and wasnt impressed. I got bad heat soak and it sounded silly. :rofl:
I have a Neuspeed kit on mine and it uses a big metal divider to stop heat soak and uses the cold air feed as well. I've definitely noticed a difference. Just don't buy one that sits under the bonnet and sucks a load of warm air in.
Plus it does sound fruity, defo not silly. Haha.
As already stated you're better off fitting a Green Cotton, K&N etc replacement panel filter in the standard airbox rather than an induction kit that sucks hot air from inside the engine bay. CAI obviously doesn't suffer that problem.
Nothing wrong with the standard filter and airbox, so I'd say save your money for something that makes a big difference.
Such as a remap or sportier suspension.
Agreed. :thumbup:
so what sort of cai's would u recommend as i also two was thinking of a induction kit but if heat soak and maf problems happen i would rather spend the extra money and get a cai or panel filter so what panel filter or cai can u recommend
thanks all
thanks all
i brought a green pannel filter and had it in for a day and put the standard back in
didnt make any difference infact seemed to lose power
this is why i was thinking of a induction cold air feed for mine
ebay do a few cheaper ones meant to be ok
but i think im going for the k&n 57i
The best filter bar none for it is standard!
Leave it alone cones are a no no and the panels let dirt in and arent really that good,
just leave it with the paper one :thumbup:
I'd agree with leaving the standard one in.
IIRC, the filter we have is the same as a 300 odd BHP Audi (Can't remember which ne, maybe the S4?)
With regards to the filter on the maff/no CAI so we get heat soak...
I went to ultimate dubs a while back and they had these billion BHP cars and they where basically doing what we say you shouldn't on the AUQ engine. Do they know something we don't? I can get pics to explain if needed.
But they drop thousands in there cars and if this can kill an engine, why are they doing it?
Get pics, as my guess is if there show cars it'll be for the tidy uncluttered look of the engine bay :thumbup:
An engine needs cold/dense air to be at it's best. not warm air which is what a cone slapped on the end of the maf will be getting.
1.8 t engine and look where the filter is. There can be enough air going to it.
Yeah, you're right there but even the small amount of time they are being used it can't be that good for it!
Show cars all neat n tidy n smooth that's why. I've seen some running no filter at all to get the less is more look.
the one im thinling of getting is this one the cone will be down behind the front grille under the arch somewhere
will this still be to close to the heat or ok?
http://www.knfilters...px?Prod=57-0430
My dad suggested that one to me. Answer was noooooo lol.
Lol, no I Dnt think I'd fancy running no filter. Trailer queens only!
The k&n will be ok. I used to run one of those eBay specials but replaced the filter with a k&n cone. Had it on a year and it was fine, now run a k&n panel in a modified airbox with a 3" feed down to the bumper, IMO it pulls better than it did with the CAI it's just not as noisy :thumbup:
this is the one i was looking at
k&n with cia so should be able to go under the arch for cold air
http://www.knfilters.com/search/product.aspx?Prod=57-0430
No don't get that one as it is not a CAI as such. It is just a bolt onto MAF that will cause heat soak. The plastic cold air pipe would be unless on that so forget it.
thanks all
Any CAI that is going to come with a full length metal tube that routes the cone filter away from the engine bay, normally down towards the front bumper area.
Piper do a Viper kit, or a tornado kit.
Forge to a good quality kit
I have the ABD kit (similar to forge) that use a K&N cone.
few pics to show you where it fits.
I use a CAI and it goes down past where the airbox wouldve been, down the side of the battery and into the bumper, did have to twist the horn unit a little bit so that it wouldnt rip the cone filter. Also be careful you go through the duck ponds that form in the road after heavy rain as drenching your filter cant be good, the last thing you want is sucking water up :)
Sounds a bit beefier but nothing drastic.. as its a turbo,
I was more towards an open cone filter on a CAI because the Recirc Valves sounds even more beautiful on let off.
Being a Skoda and having a hint of quality about them now theyre part of the panzerfaust elite the induction may not sound as sporty or the RV sound as loud inside the car as the NVH i find is rather good, but from people outside reports are it sounds nice but not too chavvy.
Edited by Milkybadger
i thought that the pipe on the k&n was the same
with the pipe going down so you put the filter down by the front arch / bumber
The pipe in that kit is the cold air feed not what the filter goes on. If you want a k&n you need to be looking at the typhoon version
I always liked the Carbonio....they was stunning
Did the job , also sounded supeb with a Forge 007P on too
oh the old days......
But I know Awesome don`t do them anymore.....shame
But I do know that there are a couple of second hand ones for sale on other forum
Oh wow , nothing nicer than the sound of them two together......
Sarah
