Felicia 1.8T transplant thread
  • 4 weeks later...
  • Replies 360
  • Views 192.2k
  • finally got the car on the road today all legit. Still a few finishing touches to do
  • When you compare it side by side with another one it looks totally oem stock except for the glimpse of the intercooler through the bumper, and the stance is a little bit more aggressive compared to a
  • Busy engine bay, fits in there like it was almost made for it, I got a really good deal on the insurance too, all modifications declared £440 fully comp.
after some proper decent road testing i've had a few minor teething issues that have sprung up, firstly i popped one of the coolant hoses at the base of the expansion tank which spat all the coolant out on the road, this was caused by not having a long enough hose which was little too tight so it popped when the engine moved under load. i've re-routed the coolant hoses in this area now and it seems fine now.. secondly i've got a noisey outer cv joint on the passenger side, but only on medium to full lock and it only does it when the engine is on load, ie when the weight shifts, when it's coasting or at low speed it doesnt do it, the angle of the passenger side driveshaft is not ideal and i think when the weight sifts it just pushes it past its operating range so it vibrates, plan is to shift the engine back slightly on the gearbox side and also use some stiffer engine mountings
my calculations are telling me that i'm getting 41mpg from this car, i've either made a mistake or it's a lot better than i expected
Sounds right, vrs 's are quite economical when driven right and your engine will be pulling less weight around too
Sent from my GT-I9300 using Tapatalk
A very pleasant side effect :)
I'm jealous!
the shopping list has started again...
first thing to sort out is repositioning the engine slightly on the passenger side
then the exhaust system needs re-working
  • 4 weeks later...
Great read Tom, loved the way the car is NEVER finished, you think it is but something else always turns up.
That's what projects are all about.
How are you going to move the engine back on the pass side?
Will you have to modify the reworked inner arch and uprated mounting plate and mount?
What sort of amount of engine movement (mm/inches) are you aiming for?
You've done an amazing job of the conversion and getting rid of the poor bodywork.
Any changes we will still need to see the updates.
Thanks once again for the link.
Cheers Pete.
  • 4 weeks later...
hello Pete, all will be revealed ASAP, I had a fancy spacer Cnc milled which offsets the gearbox towards the back of the engine bay instead of the straight through bolt on jobby I made before, it should be back from the machine shop tomorrow but I'm going to busy busy tomorrow and all weekend so I'm not going to get a chance to play..
on the subject of engine movement under load I think I might have alluded to earlier, I've got some vibratechnics engine mounts on the way (mk4 golf type) to reduce the movement, plus I've reworked the rear lower engine mount so that it slightly shorter so it holds the engine more in an upright position and it uses a solid bush made from an engineering plastic called delrin rather than a polyurethane type I used before...
also a new ecu is winging it's way to me, I had problems with my original ecu, many thanks to those members here that made this possible, you know who you are.
Updates to follow.
Nice to here the update tom sounds like you know how to fix it just wish my fun did not have tin worm lol hipe to see this at some shows...
Tom, only just noticed how you did the torque reaction link under the gearbox, you really do need to get the 2 bushes level in a horizontal plane otherwise it will cockle the torque link and allow the motor to move back under load, been there done that one lol. looking good tho
Jim, I think we must be on the same wavelength on that subject, I had rapidly come to the same conclusion myself, the top of the engine moves back, and the bottom moves forward, kind of like it's pivoting on the side mountings, hence why I've reworked it. There's still once last dimension I need to complete it but I need to fit up the new spacer and the vibratechnics engine mounts before I can finale the drawings, then it's back off to the machine shop
The other thing I've observed by strapping a gopro camera underneath the car is that this part
is flexing when A high amount of torque is applied to it, after all it was only designed for a 75bhp engine, when it gets a kick in the teeth from the big 20v engine it squirms about, it's only thin 1.5mm steel plate which is folded and welded to shape, so I'm either going to fabricate a new one or reinforce this one by adding spars to the outside... But like you say, it's important that this thing is perpendicular to the to the load applied to it, I don't know why I didn't think of this before tbh.
Vibratechnics engine mounts, crikey these things look the business, properly solidly engineered items
Cnc bling
this is a spacer that goes between the engine mount and gearbox, I've offset it so that the gearbox end of then engine is further back in the engine bay.
Updates soon.
Beautiful awesome build
  • 4 weeks later...
Hybrid k03 turbo coming soon.. Plus various other bits and pieces.
Awesome!!
I like it how you say it's too much power, then go for more! :D
Do you have a turbo lined up?
Yes, CR turbo engineering are on the job, went up there today, my current turbo has a massive crack in the turbine housing so it not long left for this world tbh. I wasn't specifically looking for more power it just struck me that if I was going to that much trouble to fit another turbo then I might as well do it right first time, It's not going to be easy to get the turbo out from it's hiding place down the back of the engine and I don't want to have to do it again.. I got a second hand turbo from a breakers yard to use as a core.
Will you get the turbo changed with the engine in place, i have been curious what access there is for maintenance in the Felicia bay...
I have a CR k03 hybrid (rs6 internals?) i got carried away and bought it last year.
I had been trying to sell it on to put the funds towards my conversion, but if i still have it i'll fit it when i get around to the conversion.
I have the same turbo - stage 2 hybrid. I still don't have a copy of the dyno plot, just reminded the tuner. But it made 245bhp at the wheels apparently.
The one I've bought is the stage 1 version, with rs6 compressor wheel and cut back turbine, 360 degree roller bearings, and also I've requested they use a garret t2 actuator instead of the BorgWarner one because it's smaller and it will help me with a minor clearance issue.
yes it will be an absolute pig to get the turbo out. If it's going to be too difficult I will just lift the whole engine out, I'm also going to be changing the cam chain tensioner and oil pump, plus fitting a shallow sump kit at the same time all in one go, also still not fitted the above vibratechnics engine mounts yet, thought I'd leave it till it's all coming apart.. Was planning on taking the car off the road when the tax expires in a few days, Then I can get it up on dollies in the garage and work on it at my leisure.
I wish I knew you were trying to get rid of one before I'd handed over a big bag of money.
edit; haha if that's the tax expiring that means Its lasted 6 months so far.. I'm amazed actually!
Fantastic build. Will you be bringing it to any of the skoda shows/ meets? Would love to see this around castle Combe :)
possibly yes, quite busy with work at the moment though.
Cool, it's amazing how you've kept it so stock looking :)
